#41
That '74 is a nice driver quality car. Needs a cosmetic resto to get the huge dollars, and it's a 1974 non A/C Auto..
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
#42
I am probably one of the few.. I prefer a non-A/C car as the A/C is just in the way. My '73 has working A/C and I never use it. These old A/C systems are kind of a waste on a 90+ degree day IMO. They don't perform like a modern car. When its 90+ out... my classics stay in the garage and I drive one of my modern vehicles.
Current Pontiacs - 1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1974 Formula 400 - Ram Air automatic 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
The Following User Says Thank You to 71GP76TA For This Useful Post: | ||
#43
Do you want to trade for my non-working A/C...
#44
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
#45
If the A/C system is fully charged with R12 and other parts are clean and proper, there should be no reason it can't chill you out of the cabin, even on a humid 90 degree day. Those systems were more than capable if the condenser is clean, and the correct refrigerant is used. I get 38 degree air out of the ducts on my 1977 T/A during a hot day.
The Following User Says Thank You to 77 Canamman For This Useful Post: | ||
#46
I purposely looked for a non a/c car way back when I was looking for a classic car. I know I'm not driving it everyday so in the summer I don't mind just driving with the windows down. I don't like the extra clutter and weight under the hood.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
#47
#48
Just curious. On a 2nd gen F Body, there is a large foam seal in the main ducting for the dash. The foam can disintegrate, and air can leak around the opening, lowering the intensity of the air through the vents. Also, the main duct under the glove box, which this seal is attached to, is a known weak spot, and can crack, leaking more air.
#49
#50
'70 T/A, RA III, 5speed, restored
https://bringatrailer.com/listing/19...d-trans-am-20/
This will go thru the roof...I like those 17's |
#51
#52
I'm really conflicted about the 17's. On some cars they look great, on others not so much. They either sit too high, or too low. This one looks fantastic, they got it just right.
But regardless, to get it right you have to lower the car some. That plus the fact that the overall tire height is less would seem to make the ground clearance too low for my comfort.
The Following User Says Thank You to jhein For This Useful Post: | ||
#53
I hear you - I'm conflicted as well
Luckly I have time on my side as I need a complete exhaust replacement anyway...lol |
#54
Wish it was blue..
#55
All about "stance and looks?" Ever driven an original car, or worse one with poly bushings with taller wheels with no sidewall... over any bumps?
The stock suspension is SOOOO Slow, the car is on the next bump as the tire is just coming down from the last.. Result.. 1 ton truck ride... GM Never put bigger wheels on these cars until they installed a much faster Strut system. One way around this is to put on Global West Del A Lum Bearings in the control arms so they move freely, and use a good gas charged shock, OR put Qa-1 adjustables in your converted ( to Global west bearings) control arms. stiff suspension beats up the car and my back....
The Following User Says Thank You to Formulabruce For This Useful Post: | ||
#56
That's another good point...the roads are horrible here and I'm due for a stock suspension re-engineering...
#57
58k and an hour to go...hard questions coming out lol
https://bringatrailer.com/listing/19...d-trans-am-20/ |
#58
I can't recall a time where I have seen a more eaten up tag, meaning that this could have been a rotted turd at one point. The pop rivets are obviously wrong.
#59
oh noes...u figure he is about to pay for a re-popped firebird?
#60
reserve not met...wth!
It's not THAT nice...lol |
