Old 08-05-2022, 01:00 PM
Just got mine looks great!! Thanks to all involved!!
  #122
Old 08-05-2022, 02:44 PM
1lms 1lms is offline
Received and greatly impressed. Thanks for getting this done.
  #123
Old 08-05-2022, 03:54 PM
FWIW the carb spacing is 3 9/16" apart front end stud to rear front stud so will check Holley spacing if 4160s will fit.
  #124
Old 08-05-2022, 05:29 PM
misterp266's Avatar
Got mine today.
Amazing! Awesome casting and machine work.
Very grateful to all involved in this project. All the hard work has paid off.
Thank you!
" Darksiders Rule "
The Following User Says Thank You to misterp266 For This Useful Post:
  #125
Old 08-07-2022, 01:37 PM
Pictures of Holleys on adapters, if you want that option.
Name:	bathtub Holleys1.jpg
ID:	596006   Click image for larger version
ID:	596007   Click image for larger version
Name:	Bathtub Holleys3.jpg
  #126
Old 08-07-2022, 02:02 PM
misterp266's Avatar
Are those just standard adapters? No mods for this intake? I have a pair of 660’s I thought about using. Looks good.
Actually, with no secondary metering plate, 660’s would fit no problem…..
" Darksiders Rule "
  #127
Old 08-07-2022, 06:44 PM
Standard adapters, 660s will need a little more spacer height for the mechanical throttle linkage they use, I have a pair I tired before I put these 715s on. As their linkage spins that big arm will hit. Regular vacuum secondary and probably DPs usual linkage will clear. The ones I put on I had trimmed the bottom tab off back in 1971 to clear my 409 manifold with them sideways. Recolored and freshened a couple of years ago by Sean at SMI.
ID:	596015   Click image for larger version
  #128
Old 08-09-2022, 11:33 AM
Center hung bowls are just a hair too long.
  #129
Old 08-09-2022, 05:38 PM
misterp266's Avatar
Couldn’t resist setting my blower carbs on it. No adapters but ya, it would work! Probably never fit under a hood though.
" Darksiders Rule "
  #130
Old 08-10-2022, 10:41 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
These 2x4 Carter's would l@@k awsome on one of those intakes!!
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
  #131
Old 08-15-2022, 02:28 PM
62cat's Avatar
62cat 62cat is offline
Default Our Royal Replica
Received my intake on Friday. Installing it on our 62 Royal Replica. Replacing the S&K tunnel ram. Making this car more Super Dutyish under the hood. My goal is to run a few NSS with SEGA and NSS at Norwalk next year.
  #132
Old 08-16-2022, 06:38 PM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
Received my manifold on Friday! Awesome piece! Thanks again!
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
  #133
Old 08-30-2022, 05:11 PM
pontbil pontbil is offline
Default Thanks
I received my new intake and just wanted to say thanks to Tom and everyone for there effort. GREAT JOB!!!!!
  #134
Old 09-16-2022, 12:01 PM
63Acadian 63Acadian is offline
Default 63Acadian
I think I'm late to the game here. I am interested in one of your late model intakes if you have any more available please let me know. Thank you
  #135
Old 09-16-2022, 12:18 PM
tom s tom s is offline
PM sent.Tom
  #136
Old 09-30-2022, 09:12 AM
mgarblik mgarblik is online now
I thought I would provide a little fitment information on the new bathtub intake into a 62 Catalina. So this is a late model intake fit into a 62 Catalina with a flat, stock hood. This intake has 1/2" spacers and a thin gasket on each side of the spacer. the AFB carburetors are genuine Carter units, 750 CFM with the large diameter air horns. {shorter carbs) With the hood installed and closed, there is approx. 3/4" clearance at the rear carb to the hood and slightly less for the front carb. ( probably about 5/8"). There is NO ROOM for a proper air cleaner of any type. As Tom S has suggested, I am going to install the Ram Air spark arrestor screens over the carbs to keep gravel and large crap out of them. This will be a temporary solution. Future plans call for the factory metal hood scoop being installed for proper clearance and more room to allow air into the carbs. My experience, at least on the dyno, is this manifold is not a happy camper with the carbs directly bolted to the manifold top. But that would gain 1/2" additional clearance. Hope this fitment info helps anyone running one in a Catalina, Grand Prix, or Bonneville.
The Following 3 Users Say Thank You to mgarblik For This Useful Post:
  #137
Old 12-19-2023, 10:47 PM
Sold out!Tom
