Old 05-11-2022, 10:15 AM
DM3 DM3 is offline
Thanks, I will hook up the mechanical gauge to that over the weekend.
Originally Posted by Joe's Garage View Post
It's the threaded port to the driver's side of the distributor.
Usually got one of those goofy square hole pipe plugs in it, unless someone has already taken it out.
IG: #67MoparBird (Follow my rebuild)
1967 Firebird 400
Appeared on Gearz, Season 16, Episode 1, Segment 'What Are You Working On?'
Old 05-11-2022, 10:45 AM
Originally Posted by DM3 View Post
Also going back to the WIX 51042XP filter since I can not get a standard size oil filter to fit due to the headers. Once we have the oil issue resolved, I will 'modify" the header since I only need about 1/4 of space to get the oil filter on.
Rather than modify the header or relocate the filter this clever and easy little mod to the filter adapter should do the trick:
https://forums.maxperformanceinc.com...d.php?t=468168
Old 05-13-2022, 09:44 PM
DM3 DM3 is offline
So a quick question, I am adding an additional mechanical oil pressure gauge. I am planning on using the port next to the distributor, will this give me a more accurate reading instead of using the oil filter housing port?
Dirk
1967 Firebird 400
Old 05-13-2022, 10:23 PM
Scott65's Avatar
Scott65 Scott65 is offline
It's a more comprehensive look at oil pressure, especially when you use both. You can see differential pressure, as the housing location is before the filter, the port near the distributor is post filter, mains, rods, and at least one bank of lifters. ( Maybe both? I can't remember)
Old 05-14-2022, 08:43 AM
Dirk
Down stream/aft filter will not change the high pressure reading at the filter adapter.
Max preassure is set by the relief spring in the oil pump.
Clay
Old 05-14-2022, 10:05 AM
Scott65's Avatar
Pressure is also a result of the internal clearances.
Old 05-14-2022, 10:19 AM
grivera's Avatar
grivera grivera is offline
Same thing I alluded to in post 13: https://forums.maxperformanceinc.com...2&postcount=13
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 05-14-2022, 11:30 AM
Tight clearances/resistance to flow would make the pressure relief, in the pump, open sooner.
Tight clearances/resistance to flow would not turn 60 psi relief into 100 psi relief.
Clay
The Following User Says Thank You to "QUICK-SILVER" For This Useful Post:
Old 05-14-2022, 11:44 AM
grivera's Avatar
Clay
good to know - thanks
Will Rivera
Old 05-14-2022, 01:24 PM
But,
If you have 100 PSI at the filter, but only 30 PSI at the engine, not good.
Old 05-16-2022, 08:37 AM
DM3 DM3 is offline
So, this weekend I changed the oil to a 5w 20, back to the Wix 51042XP oil filter and only attached the oil pressure gauge tester I bought and mounter the gauge in the car.
Oil: 5w 20
Oil Filter: Wix 51042XP
Mechanical Pressure Gauge - reads to 100 PSI
Oil PSI at Idle: 45 to 50
Oil PSI while driving in 3rd gear: 80
Oil PSI at Idle after a drive sitting in driveway: 30
1967 Firebird 400
Old 05-16-2022, 01:41 PM
DM3 DM3 is offline
So I visited the shop today and discussed the issue. They have no issues with the 30 to 35 psi at idle and operating temperature. And he said with a high pressure pump he also has no problem with the 80 to 85 psi while driving. He suggested driving it a few hundred miles and see if the psi changes or stays the same, he would be more concerned if the psi was too low rather than high.
He also said if I don't feel comfortable, to pull the engine and bring it to them and they will replace the pump. Or I could try to raise the motor enough to drop the oil pan while the engine is still in the car, but I don't think there is enough room.
1967 Firebird 400
Old 05-17-2022, 02:25 PM
DM3 DM3 is offline
I drove over to the other shop that has done some work on the car. Told them what has happened over the last 3 weeks. After driving the car for about 20 minutes, the car idled steady at 22 psi and was between 60 and 80 psi while driving.
The second shop, who is very familiar with the car, said it was fine and to keep driving it.
1967 Firebird 400
Old 05-17-2022, 03:47 PM
Have to agree with the second shop, at least at this point in time.
