Old 11-12-2021, 11:40 AM
quick67bird's Avatar
quick67bird quick67bird is offline
Default How is this cam NA and with a 200 shot
How is this cam NA and with a 200 shot of Nitrous. It seems to run pretty good NA. Hopefully I can get it to the track next year. I bought these from Crower on sale a while back. I am running this cam in a 455 with KRE aluminum D ports.
lift......Intake......Exhaust.....%
100....77.1..........62.6.........81.1
200....150.6.........114.6........76
300....204.9.........152.9........74.6
400....250...........177.9........71.1
500....288.2.........200.3........69.5
600....319.1.........226.6........71
700....336.8.........239.7........70.5
Thanks,
Robert
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
The Following User Says Thank You to quick67bird For This Useful Post:
Old 11-12-2021, 11:43 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Should work fine
Go fast, see Elvis!
Old 11-12-2021, 11:49 AM
Thanks Paul. It rumbles good on the street.
Old 11-12-2021, 12:49 PM
67Fbird's Avatar
67Fbird 67Fbird is offline
install at 106* intake CL.....wow thats a little tight? bet that has some bottom end to it.
Old 11-12-2021, 01:24 PM
It seems to run pretty good. The track will tell lol.
Thanks,
Robert
Old 11-13-2021, 01:20 AM
Brian Baker's Avatar
274 degrees duration @ .050" lift? 120 lb. seat pressure closed? Did I read that right? That's the "biggest" flat tappet cam I've ever seen.
Old 11-13-2021, 02:26 AM
It is big. I am running a bit more spring pressure though.
Old 11-14-2021, 02:36 AM
Jesus...the peaks of the lobes on it must be flat to have that much duration and still provide adequate "ramps" for a flat tappet lifter. The "baby" solid roller I had in the Discomobile was only in the low 260's @ .050".
Old 11-14-2021, 11:59 AM
Stan Weiss's Avatar
Back in the 70's I ran a GK SFT cam in my track only SBC that had 280 degrees @ 050. UltraDyne offers SFT cams up to 296 degrees @ 050.
Stan
Pontiac Pump Gas List
Old 12-12-2021, 11:42 AM
Stan
Wow Stan in a SBC that cam really must of rumbled. I need to get a better Carburetor for the street as the 1150 is a bit rich at idle and light cruising, but is fine if at full throttle or higher RPMs.
Thanks,
Robert
