Old 06-25-2021, 04:20 PM
421/376 421/376 is offline
Default WTB 66 Tempest rubber floor covering
I'm looking for a good rubber floor covering to use in my 66 Tempest wagon . My original front one is torn up. If I can't come up with a usable one I'll need to convert to carpeting .I'd like a full set (front & rear )if available . I'd rather keep it stock if possible . I believe that any 66-67 2dr ,4dr or wagon will work . I am doing a black interior . I might be able to dye if another color is found . I will be attending POCI in CT and Pontiac Nationals in Norwalk . Any help in locating one will be appreciated . Thanks , Don
Old 06-25-2021, 08:54 PM
misterp266's Avatar
I have a dark red rubber mat from my ‘66 2 dr sedan. It has a couple of holes from a floor shift someone had installed but otherwise good. If you have interest I can post up some pics. May go to POCI for a day so that would work.
LMK.
Best to PM me.
" Darksiders Rule "
Old 06-26-2021, 06:54 AM
LMK.
Best to PM me.
Thanks for the reply . If it's not too much trouble could you send me a photo or two . Thanks , Don
Old 06-26-2021, 07:41 AM
Jeff Hamlin's Avatar
Don't know how/if they differ but here's a mat from a '67 with a crazy price, but these would fall into the Hen's Teeth category;
https://www.ebay.com/itm/1967-Pontia...-/303570546437
Old 06-26-2021, 08:10 AM
Hi Jeff . Thanks for the reply . That would work . Way to high on his price .That is the same guy that is asking $3900 for the sprint intake and exhaust manifolds . Are you going t POCI ? Thanks Don
Old 06-26-2021, 09:08 AM
misterp266's Avatar
Dirty but in pretty good shape. Crack at gas pedal area (see third pic) and floor shift holes are really the only issues. I’d sell it for $150. delivered to POCI show.
Rob
ID:	568829   Click image for larger version
ID:	568830   Click image for larger version
ID:	568831   Click image for larger version
" Darksiders Rule "
Old 06-26-2021, 02:10 PM
Hi Rob, Thanks for the photos . I would need to repair them and dye them black . If it's OK with you I would like to give it another week or so before I commit to buying it . I'm still undecided whether to go that route or use carpeting . Sorry for the delay . Thanks Don
Old 06-26-2021, 04:06 PM
misterp266's Avatar
No problem but please PM me if you decide you want them as I don’t always check older posts.
" Darksiders Rule "
Old 06-27-2021, 07:43 AM
Sounds good Rob . Thanks , Don
Old 06-27-2021, 07:42 PM
Cjkgoat Cjkgoat is offline
Default Rubber floor mat
Hello. I have front and rear rubber mat from a 1966 Tempest 2 door. Can get you some pictures if interested. It's light blue. Can bring it to Norwalk. cjkgoat@cox.net 440-465-5868-Chris
The Following User Says Thank You to Cjkgoat For This Useful Post:
Old 06-27-2021, 11:04 PM
pont406's Avatar
pont406 pont406 is offline
https://www.ebay.com/itm/32318955815...53.m1438.l2649 Maybe not 100% correct, but claim its fitted for 66/67 A body, and its black! picture doesn't represent the actual product application, BTW NOT MY AD ,JUST SHARING THE AD.
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon!
Old 06-28-2021, 06:33 AM
Hi Chris , Thanks for the reply . Please send me some photos if possible . Thanks Don
Old 06-28-2021, 06:36 AM
Thanks for the info . That gives me another possibility . Don
Old 07-05-2021, 06:05 PM
I would like to thank everyone that helped me out . I got what I needed . The search is over . Thanks again . Don
