Old 10-14-2019, 01:24 PM
Cliff R's Avatar
Cliff R Cliff R is offline
"Funny when a man with 12 NHRA records cares less about LSA. In two hours I could advance your knowledge 10 years if you would understand what was being said."
Where does that leave you? We are judged by our actions, not by our words. So you bring absolutely NOTHING to the table but what you can google up with your "trolling" and I'm NOT the first bit interested in anything you have to offer, camshaft or anything else related to this hobby.....FWIW....
  #42
Old 10-14-2019, 01:38 PM
455TA's Avatar
455TA 455TA is offline
Originally Posted by pastry_chef View Post
I believe your heads flow around 300?
Yes, right at 300, maybe slightly less at 600 lift
1980 Trans Am - Street/Strip 462
Best: 7.08@95 with 1.49 60' in the 1/8th. 11.17@119.8 in the 1/4. N/A, 3700 lbs, 3.42's, Pump Gas.
Admin of Pure Pontiac Powered Outlaws on Facebook.
  #43
Old 10-14-2019, 01:47 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
With the far greater air flow demands taking place much earlier on piston descent with the stroke of a 517 as compared to a 455 it's no surprise that a Cam with 160 duration @.200" lift makes far greater power then a Cam of 140 duration at that same lift.
This fact also shows how important Intake head flow is in that lift range even if max lift air flow numbers need to be comprised to have them!
I think you're getting your posts mixed up. My old 464 or the new 517 don't/didn't have .200 durations of 140/160.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
