I weighed my low option '73 GTO 4 speed. It was 3700 and change. Not as heavy as some make them out to be. The same car with a 3.42 rear was a 14.90 car. Not exactly low on performance either. Maybe your car could benefit from a good tune..
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
Steve, that is a perfect PSD car being a 400 and no AC, hope you run it, look forward to seeing it ,looks great.
Rich Johns Owner/Operator of Pure Stock Auto Restorations Inc. www.purestockauto.com 1969 GTO Judge Ram Air IV M21 4 speed 3:90 1970 GTO Judge Ram Air III M21 4 speed 3:90 Oshawa Built 1970 GSX Stage 1 M21 4 Speed 3.64 # 67 of 678 Original Paint 1970 GSX Stage 1 Auto 3.64 # 603 of 678 12.44@109.73 mph 2011 Buick GS Nats Pure Stock, 12.71@110.64 mph PSMCDR 2011 1970 GS Stage 1 Convertible Auto 3:64 12.71@109.15 mph PSMCDR 2009 1970 GS 455 M21 4 Speed 3.42 1987 GN Astro Roof |
Here is another picture my wife took with a better camera.
Steve 71 Pontiac GT-37 400 4 spd (sold) 71 Formula 400 turbo 400 (sold) 01 Firebird T/A WS6 auto (fun) 64 Tempest Post car LS1/4L60E (Love It!) 65 Lemans Post car LS1/4L60E (More Fun)(sold) 73 Lemans GT 400/auto 1 owner 52k miles 69 El Camino LS1/4L65E (Awesome) 70 Pontiac GTO Convertible 400/400 Original 69 Olds Cutlass S W31 Numbers matching 4Spd 3:91 one of 569 |
When I had my Can Am I weighed it Milan Drag way and it weighed 4260 lbs with a full tank of gas. It was loaded with all power options.
Weight mystery
Wow, can power options really add 500+ pounds on one of these A-bodies?
It's always been a mystery to me what my 74 Lemans really weighs - some websites say they weigh 3700 or 3800 lbs (only modestly heavier than a 65-72 Lemans) and some say they came from the factory at closer to 4000 lbs (which would slow them down compared to the earlier A-bodies). Seems reasonable that the new 1973 EPA-mandated 5mph bumpers added a few hundred pounds but not a beastly 300 or 400 lbs?? Look at this sample data for 1973-74 Lemans/GTO: Ultimate GTO website says 4044 lbs http://ultimategto.com/cgi-bin/stats...1973&f1=weight BUT many other sites SAY LESS w curb weight closer to earlier models: 3628 lbs. http://classiccardatabase.com/specs....1974&model=344 Hagerty website says 3552 lbs https://www.hagerty.com/apps/valuati...pontiac-lemans 3579 lbs http://1976lemans.blogspot.com/p/1976_20.html
1974 Lemans Sportecoupe GT (daily driver) .030 over 354, #47 heads (84cc), Lunati voodoo 700 camshaft (207/213 @ .050), logs, 2.5 duals, X-pipe and Dynomax super turbo mufflers, 3.08 rear |
When comparing apples to apples, I'd think a 73 is a little lighter than 74-77 because the 73's were only required to have the 5 mph bumpers in the front, and not in the rears. It wasn't until 74 that they were required to have both front and rear 5 mph bumpers. So, the 73 rear bumpers were somewhat lighter than the others.
Steve F. |
5 mph bumpers were heavy, maybe 80 lbs each, per some posts about the '74 GTO.
You have to keep in mind that that it isn't just the bumpers, its also the 2 shock absorbers that each weigh about 8lbs, all the extra mounting hardware, the brackets, the changes to the frame to fit all the parts, the bumper fillers and attaching hardware to make the car look somewhat better. Otherwise the cars would look like some of the AMC products of the era that have the bumpers just jutting out from the body. Just look at pictures of 74-76 AMC's to see what I mean. I can see an extra 200lbs for the 1973 model year, and 300lbs for the 74-77 model years. I don't know how much they had to strengthen the frame to meet the crash standards, of if they had to increase the gauge of metal.
Then you consider that most cars made in 1973 had A/C, power steering, power brakes and the increase in size of the cars themselves, I have no problem with the average 1973 car being 300-400 lbs heavier than the average 1972 car of the same model.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
For comparison... I just ran my 73 GTO across the scales at 3,740. Here are the details...
--light weight weld wheels and bias slicks- total weight savings of 100 pounds over steel wheels and big rubber. --aluminum heads and intake- at least 100 pounds lighter than iron --Turbo 400 --factory non AC and non console. --factory manual disk brakes and manual steering Easy to see where a loaded car is well over 4k. I have had my bumpers off, and that front factory bumper is at least 100 pounds! The rear is maybe closer to 80 pounds. While this car will pull the front wheels off the ground, I might need wheelie bars if I removed the railroad tie of a bumper! Sent from my XT1585 using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
Did you ever get a chance to get a pic of your PHS?
im sorry have not as of yet but will dig it out soon as i get a chance and post it, thnx for reminding me as i havnt been on here as much as i used too.
1969 Judge, Matador Red, Black, RAIII 4Spd, Owned 33years 1974 LeMans GT Honduras Maroon, 3 speed stick 350 2brl. 1963 Catalina 389 Black with Burgandy Ventura interior SOLD 1970 GTO Pepper Green 400 YS auto Factory A/C 56K orig miles |
1975 Lemans GT parting out
hood sold
radiator stolen .... shroud hammered all else complete mouse infested under the hood interior stinks too really good parts car ... straight body with rust around vinyl top Scott 2zero6 465 9165 till 10 pacific time |
what are hoods bringing these days
-Dave
2 wrongs don't make a right, 3 lefts do. 4 lefts make a NASCAR race but who cares? ---------------------------------------------------------- 2004 Grand Prix GT daily driver 1974 LeMans GT 455 |
