Possible New Sections Here ?
Due to the obvious divide between low budget & max power Pontiac street engine builds, I propose that 2 new sections be added to this site.
These are just POSSIBLE titles for these sections: (1) Low Budget Street Engines (2) Max Effort Street Engines I figure both of these sections would be used MUCH more than many of the current sections on this site. I just scanned thru the sections. Some have not been used in months, and some not in years. I'd like to hear opinions on the possibility of adding these 2 sections, AND, exactly what is required in order to have these new sections added. |
I'd go for a transmission/differential section.
The last thing this site needs is more sub-forums.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning. |
no. For me street covers it all.
Karl |
I agree, sorta !
I think they should do away with all those that have not been used in months/years, and add some that will be used a lot. Doing this would reduce the total number of sections by quite a few. And, separating the low budget from max power builds, MIGHT reduce the number of ridiculous recommendations, for low budget, low CR, street only engines, some of which will never, or at least very seldom ever rev past 5000 rpm. MANY of the opinions totally ignore the goals of the OP, instead posting what will make much more high rpm power, & posting how quick their car went with more power. Last edited by ponyakr; 10-17-2018 at 10:38 AM. |
nope. For me street covers it all
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
And just how and who is going to decide what is a Low Budget Street Engine and a Max Effort Street Engine ! The obvious, everyone has a different budget to work with and opinion.
http://i.imgur.com/9ngaMPI.jpg Onward thru the fog. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 10-17-2018 at 10:42 AM. |
I think it would limit some exposure to the threads. Some people who now have higher budget builds do have experience with low budget builds. Myself I have done a few low budget builds that produced decent to better than expected results. But now I have the ability to do a more mid range build. Still not max effort. But have benefitted from the experience and advise from people with max effort builds. ...so I dont think the new sections would benefit us.
I'd say the biggest glaring error of this forum is the lack of a Boolean search function.
For instance the ability to search for "Brake + Lines" and only the posts with BOTH of the terms will show up. Right now if you search for "Brake Lines" you'll get every post with either Brake or Lines in it. Makes the search function pretty hard to use when there are hundreds of thousands of posts. Even just the ability to search for a term in quotes, where it will only return a result if the exact quote is found, would be great. |
If 64speed would just post all of his stuff on the thread that he created for his project, that would clean up the street section quite a bit.
This is exactly what is needed.
Britt
1975 Firebird / 1970 4" stroke 400, 6.800" Rods, 87cc Edelbrocks, XR-288-HR roller cam, Harland Sharp 1.5 roller rockers, Edelbrocks Pro-Flo4 port fuel EFI, Super T-10, 3.73 Posi. |
I feel the current street section covers it all. I like both low budget and high budget, but who is to determine what the budget is for a given individual. Everyone has a different opinion of what they consider expensive.
I like budget, but I'll pick quality first over price, and by no means does "budget" insinuate cutting corners. Hence the reason why better suggestions (in some peoples opinion) are given. People will still do what ever they can afford. I think this forum already has too many sub forums. Most of which doesn't even interest me, and I don't have the time to fish through them all anyway. |
We could have trash or be trashed like Yellow Bullet!
"...but who is to determine what the budget is for a given individual..."
Just from what I've read, seems like maybe new alum heads & a roller cam might not be what many would consider to be included in a low budget engine. Even basic iron head engines, built by the big name Pontiac shops will many times cost $10k & more. To me, $10k is not a low budget engine. There are lots of guys who can't spend more than $5k-$6k on an engine, some even less. But hey, if you got the money, spend it. I would ! |
Banned items
Bug killer ignition Electric fan Electric water pump Roller cam 290-350 cfm aluminum heads NOS Line Lock Holley carb Flowmaster mufflers Single plane intake 3600-5000 RPM converter 3.70, 4.10, 4.30 gears .
Solid advice for an 11 second car.
What about the guys with a $2,000 budget who want a 650 hp street engine that gets good gas mileage, and will make a great daily driver for at least 100,000 trouble-free miles?
1965 Pontiac LeMans. M21, 3.73 in a 12 bolt, Kauffman 461. |
