Not Installing windage tray. Number 3 main cap does not have boss or 5/16 holes for lower dip stick tube bracket. Any ideas on how to mount lower dip stick tube?
Drill and tap the two holes on the #3 main cap. No big deal to do so. Or, you could go with a Canton pan that has a dip stick provision built on it.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
The Canton takes its own dip stick,adds $100 to it,also a oil pump pickup which adds more.You can drill the inside of the Canton to use a factory dip stick.Tom
Be sure if you do drill & tap that you either use a bottom tap after the normal taper tap, or you confirm that the hold down bolts you use do not bottom out in the new main cap holes , as if they do you chance cracking the stock regular gray iron caps!
Not a fan of drilling the main cap as it is curved and not a lot of metal to work with. Any way you could silicone the lower tube into the one pressed into the block or pin it somehow.
I don't have the lower tube in mine. The tube broke off from the mounting bracket and I found it laying in the bottom of the pan the last time I had it off. I left it out when I put it back together and I can still check the oil just fine. You might have to re-mark the dipstick though. DO NOT run the engine with the dipstick in the tube if you leave the lower tube out.
'68 Firebird 463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 9.93 run - https://youtu.be/hII0_UlYM4U ![]() |
The Canton pans are nice with the dipstick provision.20 bucks for a nice dipstick is a deal.
Which oil pan? I have the kick out pan and used the top plug on the pan for a dipstick. Made it from braided line and 8 am fittings
Gee! How does the factory drill the main caps if there curved without a lot of meat there?
The factory caps that are drilled are higher and have bosses for them. My number 3 cap is not nearly as thick above the crank as number 2 and 4 are.
Are you using main studs?
Just a thought, a stud similar to what is used in a Milodon wind age tray install would give you a point to attach the lower tube extension.
