Valley pan source
I am looking for a new valley pan for a EGR intake and hyd roller lifters. I have checked PY/Ames and Butler. No luck. My EGR intake came from SD who ported it and did their other little mods, so I am not willing to replace it. Any suggestions?
You have no pan now?
Is your problem the combination of hydraulic roller lifters and the EGR intake? Like you are searching for an after-market valley pan made for such a combination? If so, I don't see one either.
If you can modify a stock EGR pan for the hydraulics, Frank's has one. http://www.frankspontiacparts.com/en...ngineparts.htm BR's, Mark
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
Dan
What year is your EGR intake ? I believe 73-74 EGR intakes would be the same...and 75-78 EGR intakes would be the same (as we know 78 intakes were also used in 79). I modified ( hammered) some clearance into the Tomahawk valley pan to work with my 78 cast iron intake and hydraulic roller lifters. I also did a touch of grinding on the bottom of the stock 78 cast intake - very minor grinding -pretty well all the additional clearance was by hammering the Tomahawk ...see pics in this thread http://forums.maxperformanceinc.com/...ght=valley+pan |
Dan
Just a bit more info I found that my hydraulic roller lifters were hitting my stock 78 valley pan...this is a known issue...see my post for pics http://forums.maxperformanceinc.com/...ifters+hitting |
I do, but I did not do it any favors when I tried to "clearance" it.
I have one of the aluminum ones I'd sell. It has no hole for the PCV.
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
I have a 78 EGR intake on the 350 currently in my car. The intake not have the huge EGR sump underneath. The 76 and up (not exactly sure when they got away from the deep sump EGR style) EGR intakes will work with the earlier valley pans. My 1970 350 has it's original valley pan with the 78 EGR intake. My main purpose for mentioning this is to let folks know the latest EGR intakes don't need the valley pans with the huge recess in them. I find it strange that Pontiac kept using the recessed valley pans with the later EGR intakes that did not need the recess...
Butler.
