Old 06-22-2016, 06:55 AM
Pepi's Avatar
Pepi Pepi is offline
Default 4spd speedo cable routing
I have this posted in the 70-73 section, ref: http://forums.maxperformanceinc.com/...41#post5593041
So how many people have seen the speedometer cable routed underneath the transmission and how many have seen it routed over the transmission?
Just trying to get a sense of which way is correct?
Name:	Bob's TA 1.jpg
ID:	431355   Click image for larger version
Name:	Bob's TA 2.jpg
ID:	431356   Click image for larger version
Name:	TA 4 spd.jpg
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 06-22-2016, 12:16 PM
superdutybob's Avatar
superdutybob superdutybob is offline
I posted this over there!
When I got my 74 SD 4 speed car it had the cable mounted over the transmission. Can't state whether it was correct or not. I can ask the question "why would you change the routing if it was originally under?"
Brewster's 73 SD 4 speed, which was a meticulous concourse restoration, had it mounted under and clipped to the dust shield. That always made me wonder if mine was wrong. I never changed it.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 06-28-2016, 07:06 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Have you checked the service manual? My '71 is routed under going through the clip mounted on the shield as shown in the picture. Maybe different routing depending on transmission?
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Old 06-28-2016, 08:29 PM
Can you post a pic of the 71 manual?
Old 09-16-2016, 12:32 PM
dadsformula dadsformula is offline
My Car (Original 73, 4 speed) is over the Trans, and this is confirmed in
GM's 73 Assembly Manual. On Original 4 speed Cars there is a welded
on clip on the Drivers side Trans Tunnel, and a bolt on clip (retainer) on the
Trans Mount Bolt (passenger side) that allows the Speedo Cable Run over the
Trans then loop into the speedo Gear to avoid binding the Cable. The Welded
Clip on the Drivers side, if you look at it is to keep that Cable away from the
shift linkage. It may be gone, and even if so, a small square welded tang
should remain, and allow you to properly locate a new retaining clip.
I can't say this is correct for any other year, but I also can't imagine GM would
run any Cable across the bottom of the Car, for obvious reasons. Even Brake
and fuel lines that run across the Car are either protected by the Frame, or
shielding on the lines. Nothing that could be caught or pulled would be correct
in my mind. Now a 74 uses both the Muncie or an ST10 depending on the build
date, so this could easily have changed with the change to the ST10 in 74 but
I would bet it's the same for all 4 speeds with the speedo gear entry on the passenger
side.
Old 09-16-2016, 03:04 PM
side.
I agree 100%. I believe under to be incorrect.
Bob Woodard
Brighton, MI
Old 09-16-2016, 04:49 PM
My 73 T/A had the cable over the trans. I got this car from the 2nd owner same family & the trans & or engine had never been out fro any reason & it had only 64K on it when I bought it. The cable on it was over the trans & was routed through the welded tab on the floor pan & through a loop at the trans mount on the right rear corner of the mount.
