SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
Cleaning out sale
Timing cover 9773371, '65 all V8
Timing cover 9783130, '66 all V8 Intake manifold 9790140, date code L127 1968 all V8 $75 remote mirror 69-72, A F G P cars $1 inside mirrors '65-'66 $2 a/c bracket, short front, 2 bolts on intake to compressor, 490334, & 549501 $2 each A/C supports, cast iron, bolts to head 9779015 '65 P/T cars $5 A/C supports, cast iron, bolts to head 9789228 '67-68 F/P cars $5 A/C supports, cast iron, bolts to head 491877 '73 + all V8 $5 A/C single groove crank pulley #480509 $1 Water pump pulley, #9786819, 2 groove 8" dia. '67-'68 F , maybe others $1 P/S pump mount #9778848 '65-'66 P/T all V8 $2 P/S pump mount #9786903 '67-'69 all V8 $2 Mallory dual point distributor, Oldsmobile V8 $20 Street dominator intake, $20 Stock oil pan, baffled $10 Door pulls, $2 Windage tray, $5 balancers, $2 Flywheels, $2 7 to choose from Flywheel, 168 tooth Chevrolet, new $5 Turbo 400 trans, three of them, two short shaft, one long shaft BOP cases, $50 each Continental, tight 3000 stall converter, 10" $75 62 heads, 250 cfm, milled, x-over filled, should be gone through as they have a lot of passes on them, $200 Would have to check chamber size for sure, 68 or 69 cc if I remember right. Came off alcohol motor. Send message for anything in back ground photos, I don't have part numbers for. |
PM sent
I will take the Holley street dominator for $20 if not spoken for. Let me no shipping amount to 02062
PM sent on the converter
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
Pm sent
Sent from my XT1254 using Tapatalk |
PM sent on remote mirror
Ain't as good as I once was, but I'm as good once as I ever was. |
PM sent for '65 timing cover. Jeff
New up to date list
Intake manifold 9790140, date code L127 1968 all V8 $75 Mallory dual point distributor, Oldsmobile V8 $20 Door pulls, $2 Windage tray, $5 balancers, 400 - 455 $2 Flex plates (flywheel), $2 7 to choose from Flywheel, 168 tooth Chevrolet, new $5 Turbo 400 trans, three of them, two short shaft, one long shaft, BOP cases, $50 each one solid, A body motor mount (two bolt), '77 ? engine frame mounts $2 '65 wiper, head light switch, unknown ignition switch $5 each top alternator brackets $5 for 7 of them few other parts, will get up dated picture soon. Joe |
Joe put the alt brackets with the rest of the stuff for me thanks
I have posted a second sale in the " all other category ", I suspect this one should have been there also.
Joe |
joe,
Do you have the front ac compressor brackets for a 64-65 ? |
Sold Out, sale is closed
Thanks everyone for helping clear away my parts.
