Old 06-12-2016, 09:51 AM
The Boss's Avatar
The Boss The Boss is offline
The Hot Rod Garage is one of the best restoration shops on this board!
And go racin' in the street.
  #342
Old 06-12-2016, 10:57 AM
Bentwheelbob's Avatar
Originally Posted by Brewster View Post
Does Dave get a Hat now???
Thanks for all the kind comments. Actually MPD had the hats made up for me as a Cjhristmas gift. Pretty cool, huh? Just need to get some now with the Red Car.
  #343
Old 06-12-2016, 12:07 PM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
Awesome job! Gets me motivated to work on my car! Looking good!
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
  #344
Old 06-12-2016, 12:37 PM
SD455DJ SD455DJ is online now
Bob, That is a great picture of you and Dave! The car is totally frickin' amazing from all the hard work you two are putting into it. I can't wait to see it in person.
Dennis
  #345
Old 06-12-2016, 01:29 PM
bird72's Avatar
bird72 bird72 is offline
I think The Hot Rod Garage should have live video feed with web viewing. Multi camera of course. Cars should probably have engine cameras. My money is those two have to occasionally throw wrenches at each other
72 Bird
  #346
Old 06-12-2016, 07:40 PM
Thanks again for the kind comments. This is such a cool car. It's a ball to work on and get it polished up while retaining the original patina. BTW - Dave and I never throw wrenches at each other, but he would tell you it's because there are never any lying around due to my OCD cleanliness. The key to keeping MPD happy is to keep him well fed. Today we had smoked ribs and brats, and homemade fries.
It was another long day, but we got a lot more done. The car is back inside the garage, and the new flywheel, clutch assembly, and transmission are installed. I struggled with putting the clean, but rusty crossmember back in without paint, but I think it's the right thing to do. The transmission, bell housing, and crossmember got a good cleaning, but nothing got refinished or painted. The closest we came to that is all the bolts and hardware got a good varsol bath and time on the wire wheel to remove the rust and clean up the threads. I'm really happy at how well the shifter and rods cleaned up.
Here's a few pictures....
  #347
Old 06-12-2016, 07:46 PM
The Boss's Avatar
The classic pose!
Bob, you didn't want to give the cross member an evaporust soak?
  #348
RamAir's Avatar
RamAir RamAir is offline
Default The Red Car has a new caretaker
Im proud of you for your restraint in preserving the cars original finishes. Outstanding
  #349
Old 06-12-2016, 07:54 PM
Norwood's Avatar
Norwood Norwood is online now
Dave right back at you
  #350
Old 06-12-2016, 08:10 PM
The classic pose!
Nah, I'm not sure where that process stops. First the crossmember, then you have the subframe arms, then the driveshaft, the rear axle, the leaf springs....IMO unless you are ready to do it all, it looks much more natural doing none of it. If the gas tank hadn't been painted I would have left it alone.
Speaking of which, I used heavy duty chemical paint stripper to initially soften the paint, and then finished it with an aerosol citrus stripper and a green scotchbrite pad. I would do a section and Dave would immediately pressure wash it. The key was to work the scotchbrite aggressively with the grain of the steel, and the citrus stripper was an excellent lubricant. Sort of like wet sanding.
Norwood - Dave and I are a package deal, sort of a two for one special. However, neither of us work well without a lift.
  #351
Old 06-12-2016, 09:02 PM
Is that how you stripped the paint from the fuel tank? Since mine has been painted, I'm curious as to how you got yours looking so good.
  #352
Old 06-12-2016, 09:20 PM
Yep, that's it. Sorry for the delayed response. The chemical stripper was also an aeresol, but it flashed pretty quick and would just dry. I coated the tank once with it and let it do its thing and then dry. I then coated smaller sections with the chemical stripper and used a plastic putty knife to clean off what I could without being too fussy. After that I switched to the Citrus Stripper aeresol that had no flash point. After soaking for thirty minutes or so I went over the whole tank with a green scotchbrite and then power washed it. Following that I got a fresh scotchbrite and worked sections at a time with the Citrus stripper being careful to work the pad with the grain - front to back. After each section was finished it was power washed. I probably switched scotchbrite pads a couple times during the last stage to make sure it had plenty of tooth to give a nice directional finish.
I've been following your Formula rehab project and it looks great. You did a fantastic job in the trunk. Please share on your thread your experience with the trunk spatter paint. I have heard so many horror stories, but yours looks awesome.
  #353
Old 06-12-2016, 11:40 PM
Norwood's Avatar
Maybe I need to spend a week in coal country.
  #354
Old 06-13-2016, 03:37 PM
You would be welcome any time my friend, but I'm not sure I can match the hospitality or charm Bill affords you on your Memphis pilgrimages.
Hop in the Blue Car and head down sometime, and I'll clear off a lift and give you free reign. Who knows, MPD might even give you a hat....
  #355
Old 06-13-2016, 05:12 PM
Brewster's Avatar
Brewster Brewster is offline
Did someone say road trip? Hey is it me or is Dave putting on some weight??? I dont remember that finger being so fat?
  #356
Old 06-14-2016, 03:19 AM
Transamric's Avatar
Too many brats lead to FFS,..........Fat Finger Syndrome.
  #357
Old 06-18-2016, 08:45 PM
So, the Red Car is all back together and on the road. A few tweaks are still needed, and the paint buffing/polishing remains, but the heavy lifting is pretty much finished. The tranny and new clutch are in and adjusted, the exhaust system is on, driveshaft back in, basically all is good.
I went with a LUK clutch and love it. It feels great with the right pedal effort, and it hits all the gears including reverse with no problem. The exhaust system is a Gardner from the Black Car, and frankly it was a bigger pain than I expected. I think mainly that's because it was used and had tight clamp areas already that made it a little harder to adjust for a different car. After a long drive today, one thing I am difinitely not thrilled with are the repop spiral shocks. They have very little dampening effect and generally suck. There has to be a better solution.
It's interesting that the right side has more overspray on the floor pan than the left side. I know NJSteve has a similar situation on his much higher mileage SD (), but I forget if it is also the right side.
Here's a few pictures. I love this car...
  #358
Old 06-18-2016, 10:06 PM
RamAir's Avatar
That it a thing of beauty
  #359
Old 06-18-2016, 10:09 PM
West Coast GTO's Avatar
West Coast GTO West Coast GTO is offline
The car is beautiful; much better than I could have ever done! Were the original shocks rebuilt or did you go with different units. I remember that the aftermarket shocks that were on the car really allowed for great handling.
  #360
Old 06-19-2016, 06:50 AM
Michael - you did a great job with the car tackling a lot of the messy and difficult mechanical jobs. This has made it easy for me to focus on the little details that remained. I looked into having the original shocks rebuilt, but the quote was almost $300 per shock to rebuild and retain the original patina. I'll be looking around at other options for the original spiral shocks and will definitely replace the repop spirals with something else.
How is your hunt for a GTO going?
