Old 04-22-2016, 07:10 PM
SD455DJ SD455DJ is offline
Thanks Doug for the list!
  #402
Old 04-22-2016, 08:03 PM
Alternator Numbers Search
  #403
Old 04-23-2016, 11:13 AM
Thanks John. I believe it is the original alternator.
  #404
Old 04-30-2016, 10:53 AM
Latest progress...Dan & I removed the hood and I scrubbed the grease and grime from 45 years off of the underside and then, in a moment of weakness, decided to "RAM AIR" it. The hood alraedy had the RA screens installed in the scoops, and Mike (Judge273) sold me an original '71 RA air cleaner, and I had NOS black '71 'Ram Air' hood decals....so, pulled the trigger. While I did that, Dan swapped in an original '71 Delco distibutor and repop spark plug wires for the MSD billet distributor unit that the car came with. We set it up with stock points and is set at 12* initial with a full advance at 41* @ 2500 rpm, and 50* with vacuum advance. Should work well with the 8.2 compression and the Summit 2801 cam (214*/224*/112*@.444"/.466").
Found the AO Smith embossing and the original factory crayon date on the front hood bulkhead (2-12-71). There are alot of black paint runs along the back edge of the hood near the vents which may be factory??? I'm not sure, but it is satin black and has canyon copper overspray.
Name:	Cleaned bottom_resized.jpg
ID:	427399   Click image for larger version
Name:	Crayo nDate_resized.jpg
ID:	427400   Click image for larger version
Name:	AO Smith mark_resized.jpg
ID:	427401   Click image for larger version
Name:	New RA Boots_resized.jpg
ID:	427402   Click image for larger version
Name:	Paint runs_resized.jpg
  #405
Old 04-30-2016, 10:56 AM
A few more...
Dennis
Name:	New Distributor_resized.jpg
ID:	427406   Click image for larger version
Name:	RA Boots_resized.jpg
ID:	427407   Click image for larger version
Name:	ram aired_resized.jpg
ID:	427408   Click image for larger version
Name:	Ram Air hood_resized.jpg
ID:	427409   Click image for larger version
  #406
Old 04-30-2016, 10:57 AM
Default The Canyon Copper Club
Now taking memberships....
Name:	A&F Canyon Copper_resized.jpg
ID:	427411   Click image for larger version
  #407
Old 04-30-2016, 11:46 AM
RamAir's Avatar
RamAir RamAir is offline
Excellent decision, anything Ram Air I'm good with
  #408
Old 04-30-2016, 12:35 PM
Pepi's Avatar
Pepi Pepi is offline
Looks good.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #409
Old 04-30-2016, 02:15 PM
Brewster's Avatar
Brewster Brewster is offline
Car looks great Dennis and the paint has great depth. Pulls you right in! glad to see you got some plates on it to finally take that thing for a test run. Please let us know how it is??
Love Dan's GT37 in the neighboring stall. Killer car and would love to see him pull a few runs someday. Cheers and look forward to a road trip soon.
Cheers, Brew
  #410
Old 04-30-2016, 05:05 PM
Bentwheelbob's Avatar
Dennis - Car looks great and you keep making fantastic decisions. Did you and Dan have a chance to take it around the block after you got finished?
Can't wait to see it in Dayton. Thanks for sharing.
BTW - be sure to keep the hood unlatched when garaged.
  #411
Old 05-01-2016, 09:24 AM
The Boss's Avatar
The Boss The Boss is offline
Very nice detailing on that hood. Matches everything I've seen in them over the years.
And go racin' in the street.
  #412
Old 05-01-2016, 09:40 AM
Judge273's Avatar
Judge273 Judge273 is offline
One sweet Air Cleaner!
Mike/Illinois
  #413
Old 05-02-2016, 12:55 PM
Thanks for the compliments Doug, Karl, Brian, Bob, Chris, & Mike!
Brian & Bob, I am still waiting for the registration for my plates to come back, so I've only driven it 100' total so far (lol). Still owe everyone a burnout video!
Bob, Yep, the hood always stays unlatched while garaged. I don't want the dreaded bulge!
Mike, Thanks for selling the RA unit to me, now I have to find the correct breather tube, upper dip-stick tube (HO specific), snorkle braces, and heat riser elbows.
Dennis
  #414
Old 05-02-2016, 09:54 PM
PureSD's Avatar
PureSD PureSD is offline
Love it Dennis
1972 Trans Am Lucerne Blue /white 4spd
1973 Trans Am 455 4spd, White/Black..Junior Gold POCI 2012
1974 Trans Am SD455 4spd. 29k mile unrestored. Buc Red/white
1948 Lincoln Continental Cabriolet V12. Restored.
1951 Willys Jeepster 6 cyl.
1968 Olds Cutlass W31 Ram Rod. Nocturne Blue, 4spd, stripper
1969 Hurst Olds survivor
1970 Challenger RT Convert . 383 4spd. Plum Crazy/white
1971 Datsun 240Z
1978 Datsun 280Z Black Pearl edition
1983 Jeep CJ7 Renegade
2013 Corvette Gran Sport
  #415
Old 05-03-2016, 12:19 PM
Thanks Sean!
  #416
Old 05-09-2016, 12:54 PM
Default Steelies & Dog Dishes
Here is the alternate wheel/tire selection...15x7 steel wheels (from Dan's T-37 when he once raced it with G60x15's) and BFG 255R60/15's curtousy of Bentwheel Bob. The wheels are painted Castillion Bronze, like the original 14x6 steel wheels that came from the factory on the T-37. A-bodies only had 5 wheel color paint choices available (black, castillion broonze, laurention green, baja gold, and lucy blue(?)), so this technically isn't factory correct as Firebirds could get all availble colors for steel wheels when no trim ring or wheel cover was ordered, but same as the body color. I do like the contrast and it is staying that way.
BTW, I reused the original SS capped lug nuts on the steel wheels. I hadn't yet read the thread about what lugnuts were original with 14" & 15" Rally II's or HC's. My Formula's build date on the body tag is 05B, so no controversy with what nuts it came with.
Let me know what you think vs. the HC's....Dennis
ID:	428063   Click image for larger version
ID:	428064   Click image for larger version
ID:	428065   Click image for larger version
ID:	428066   Click image for larger version
  #417
Old 05-09-2016, 01:01 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
I'm all about those plain steelies, Dennis. Run with those. Besides, you'll save about 150 lbs. over the HCs!
Regards,
"455HO" Lloyd
  #418
Old 05-09-2016, 01:04 PM
RamAir's Avatar
Both are super cool, but I prefer the honeys
  #419
Old 05-09-2016, 01:06 PM
Lloyd-TX's Avatar
Thumbs up
Never been one to pass up the opportunity to show off my old Sundance GTO, here's a pic with the freshly installed steelies.
Regards,
"455HO" Lloyd
  #420
Default Decifer Honeycomb Date Code Please
Does this stamp code on the Honey's from the Formula read November 30, 1970?
oops! Sent the wrong pic without the doggies on...
Thanks, Dennis
ID:	428068   Click image for larger version
ID:	428069   Click image for larger version
ID:	428070   Click image for larger version
