Camber Change
How much change in camber should you have throughout the suspension travel.
Theoretically none @ stock height, that's why upper & lower A arms are different lengths.
But go to the pro-touring site or other handling sites most production cars have a
"camber curve" that many things affect. Many guys on second gens are using "tall ball joints" to help change that some-bet some of the A body guys there have comments. Also many A bodies, as well as other cars have "Bump steer" where as the Aarms cycle through their range it changes steering toe also. Something using taller spindles like F/B body spindles on A bodies for better brakes will affect. Baer and others even have a bump steer kit to adjust some for that.
