Old 10-28-2009, 01:05 PM
AJD1964's Avatar
AJD1964 AJD1964 is offline
Hey - Those look pretty good.
Can you post info as to how to get them?
Thanks, Tony.
'71 Formula 455 HO Ram Air - Future Project
'64 GTO 389 4bbl 4-Spd. - Nice Driver
'71 Lemans Sport Conv. Modified-350/350 3.23 Posi - Driver/Project
Old 10-29-2009, 09:42 PM
Pecosbill's Avatar
Those do look good. What's the source?
Pecosbill
Old 10-30-2009, 06:57 AM
chrisp chrisp is offline
I have spent a lot of time to find this part but i think it is the closest part available . I purchased it from Zip product , it is from a corvette supplier part # is SU - 1148 63 =67 15/16" F41 . I am now seeking any info on a lead for a correct 64 GTO clutch rod through firewall boot . The chevy repo. is incorrect . Any leads on a nos or good used 1 is appreciated . Thank you
Old 10-30-2009, 07:42 AM
John V. John V. is offline
You can copy and paste the two Zip.com links to your browser that I provided in post 14 and it will take you to the parts, both the 3/4" and the 15/16" ones.
Old 10-30-2009, 10:07 AM
AJD1964's Avatar
Thanks to you both!
Tony.
Old 02-15-2014, 07:25 PM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
Default Sway Bar Bushings
I didn't mean to resurrect this old post, but I'm having a very hard time finding the correct sway bar bushings.
The one on the left is the original (I think) next to the bracket; next is the one in this post that was supposed to be NOS; and last is the one the end of the post finally said was correct. I think I've spent way to much time looking for these and certainly too much money.
As you can see the replacements do have the rise in the center, but are either not wide enough or don't fit at all. I've tried our sponsor and got something not even close and the local part store (NAPA; Bennett; etc.).
Can anyone help with this?
ID:	353167   Click image for larger version
1964 GTO Auto
1970 GTO Ram Air III 4-speed
1972 Lemans Convert with endura option, 455, 4-speed
Old 02-17-2014, 02:45 PM
AJD1964's Avatar
Terry - Did you try to go to the "zip" link as John V. mentioned in post 14?
I never did that yet, but if you review those posts you'll see that the guys thought they were pretty good.
Regards, Tony.
Old 02-17-2014, 05:32 PM
Yes, that's the one in the picture all the way to the right.
1964 GTO Auto
Old 02-17-2014, 09:13 PM
Terry, just to be clear, the one all the way to the right was purchased at NAPA or Zip-Corvette.com?
If from NAPA, you need to cut and paste the web address for Zip-Corvette.com that I posted in #14 and paste to your browser. It is not a clickable link in the post (not sure why, but it works if you copy & paste it). There are two addresses, one for each size of bushing.
If the one you got IS from Zip-Corvette.com, I'm fresh out of ideas. Which is a bummer, because I figure I'll eventually need a source also.
Old 02-18-2014, 10:36 AM
olde-goat olde-goat is offline
For what it is worth, when you finally source the bushings and ready to install, apply some silicone grease between the bushing and the sway bar. I failed to do this on the initial install and every time I backed out of my driveway and made a hard right or left it sounded like my car was 'passing gas'.
The Following User Says Thank You to olde-goat For This Useful Post:
Old 02-18-2014, 07:06 PM
No, I'm sorry to say the one on the right is from zip. I'm all out of ideas.
1964 GTO Auto
Old 02-18-2014, 10:02 PM
Terry, is I possible that the original was squashed down over the years and "spread" out?
Might possibly the one from Zip be dimensionally correct for a new bushing?
Or are they definitely too narrow?
Was scanning thru ebay listings, noted some similar looking bushings offered by Prothane for a '64 up AMC application, 3/4", 13/16", & 7/8" bar diameters.
Has anybody checked with Prothane to see if they have a match?
Old 02-19-2014, 07:49 AM
I have the ones from Zip on my 64 the fit is good , no noise from them as they are not real tight to the bar when mounted but work excellent . Until something else is made or discovered this is the closest we have .
Old 02-19-2014, 05:24 PM
The ones from zip will fit in the bracket but will just not fit to the edge of the bracket. I don't know if that is sufficient though...
1964 GTO Auto
Old 02-20-2014, 09:59 AM
Mine seem fine car handles nice , no squeaks either . You can always swap them later .
The Following User Says Thank You to chrisp For This Useful Post:
