This weekend I had the opportunity to participate in the last Arm Drop Live even hosted by the Pinks crew and Houston Motorsports Park's 1/8th mile track. Though I was among the slowest times in my bracket I ran a new best in the 69 and had a GREAT time.
Test and tune Friday night yielded 8.02 and 8.03 passes at ~84 mph with my old out of the box 850 DP. I decided to swap on a buddy's old HP 950 set up for his 540. Idle was better than its ever been and throttle response was insanely crisp and clean. First qualifying pass I ran a 7.63 at 91 mph. Backed up with a 7.64. Saturday morning ran one pass during test and tune and 3 more passes during qualifying. First pass was 7.57 at 92 mph! All 3 qualifying passes after it warmed up were 7.63,7.62,and 7.64. I made it in as an alternate. My group was from 7.09 - 7.69. First round I was staged with my rear wheels on the beams against a car that was running 7.10's all day, so I went out in the first round. Depending on conversion calculator used the 7.57 1/8th mile equates to a 11.75-11.85 sec 1/4!!! Previous best was 12.27. Heading to HRP Friday night to see the true 1/4 mile results. Nonetheless, .5 sec and 8 mph improvement in the 1/8th is huge! Can't imagine what it would run if I didn't have bad rings.... The new 496 will be done soon enough. In addition, mine was the only true STREET car there and it was the ONLY Pontiac motor in the event!
69 Firebird, .060 over 455, UD solid roller 254/262 @ .050, Scorpion rockers, home ported 6X-4 heads, Holley 850 DP (bone stock), Holley SD intake, with Summit 3 inch x-pipe and goerlich Xlerator mufflers. 12.27 @ 115mph. 02 Midnight Blue LS1 Ram Air Trans Am WS6 (440 rwhp) http://firstgenfirebird.org/show/closeup.mv?CarID=642 |
wow! what was the 850 jetted at etc compared to the 950 hp thats awesome!
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
WOW! Dropped a half second in the 1/8....I bet it felt like a whole diffrent car.
Nice work, -Abone.
Daily Driver Model A Ford. 389 Pontiac w/6-71. 10.80 @129.5 1933, 1934, 1936 and 1940 Fords, also Pontiac powered. |
Nice runs in the 1/8th. Post 1/4 mile times. It might be time to switch to a 950 carb.
Conrad 79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ![]() |
Sweet, it goes to validate the importance for a good fuel system. I just had very similar results after fuel system upgrade, including new carb! Congratulations!!! JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! ![]() |
7.50 @ 93 is about 11.70's @ 117-118. Nice job picking up 1/2 sec! Now you need a carb, huh? I like your combo, similar to mine....
65 GTO, 3800#, 474, KRE Dport 330 cfm, 11:1 on pump gas, XE 242 248 solid roller, T56 trans, 3.90 gear, 11.26 @ 124 mph |
Fortunately, I had already bought the 950 before I put it on.
I would still be curious as to the jetting etc differences if u know them? thanks
