Nice SD James, and what a collection!
Yep - someone in your SD cars' past thought they'd make a hot rod out of it by removing that secondary air valve link - NOT! It will run MUCH better with that link in place, and everything properly adjusted. Cliff Ruggles will have that air valve link for you - cliffshp@embarqmail.com
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
I would like to see them Bob. Thanks
1974 400 4 speed |
I would too, I'll take the same pics of the 11k mile car to compare.
Mike |
Nothing is impossible if you break it down into possibilities. It's all a matter of "Want to". |
That's..
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
Hello Lloyd,
Thanks for Cliff's name, I'll e-mail him this evening. Jay, I have attached some close-ups of the master cylinder and the proportioning valve. To my eye the master cylinder is definitely Semi-Gloss. The proportioning valve and it's mounting plate are or were an as cast finish and the plate had what looks like maybe just a clear protective coating. It looks just like a bent piece of sheetmental. I put it up on my lift if you guys need any pictures of anything on the underside. Unfortunately or fortunately, depending on how you look at it, my car was undercoated at the dealership and it can be hard to see the origional finish of some things. Youll see in my next post I also took some pictures of the steering gear. I had to remove some undercoating to get to the origional finish. Let me know if you need more. James |
On to the steering gear. To me everything looks to have an as cast finish to it, with the exception maybe of the drag link, which has kind of a blueish tone to it. That could be the light I was using and maybe a reflection off of the blue of the engine.
James |
both the center and drag link should show some blue tones, heat treatment process i believe. i cleaned all my steering gear of surface rust and crud with a wire wheel, degreased them then sprayed them with a cheap silver paint followed by wiping that off quickly while it was wet. that process filled the pits and it has held a "dirty" natural color for ten years now. am i seeing black phosphate or black semi gloss on the hood hinges? glad to know my memory of black master cylinders and steering link wasn't erroneous.
James,
This pic is great!. It shows a lot of what I have been wondering. The master cylinder color, the blue inspection splotch(exact color) and mainly that these cars did come with a booster that is etched Delco Moraine. Thanks again..this is great!
Great Jay,
Glad to help. If you need anything else just let me know. James |
It appears that the idler arm has been replaced on your car as it is not the original style. Do you know? It also has blue shocks where the 186 mile car had gray. Have those been replaced as well?
Great pictures!
Bob Woodard Brighton, MI 2012 SRT8 Charger - 12.70 @ 111mph |
Hello Bob,
It does look different doesn't it? It also did not have any undercoating on it so I think you are correct. I have not replaced the idler arm or the shocks so I'll have to pull my information that came with the car to see what I can find. Anyway, thanks, I'm making a list to put everything right on the car, so your input is appreciated. Regards, James |
Mike |
Hey James, what is your ceiling height in the garage and the maker of the lift.
Thanks Bub
1974 400 4 speed |
Mike:
I believe that the current owner is just the second owner. I'm fairly certain that it was purchased from the original owner. Not cheap but how many of these are you going to run across.
Hello Bub,
I am still watching your build closely. What you are doing is getting me motivated to start my projects. If I remember correctly I tried to build the pole barn with 12 ft ceilings but the county I live in came back on the permit and limited me on the height of the eaves on the outside. I really didn't understand why, but the net effect was the clearence is 11' 4" now. The lift is made by Direct Lift. It is a 7,000# capacity and I bought two sliding jacks that fit between the rails and allow you to lift the car completely off of the lift. They are worth the money because they make a four post lift mush more useable for service. Thanks, James |
My next step on my resto is re-attaching the subframe and assembly everything for alignment and start blocking, then take it apart and hopefully start painting sometime the first week of September. We shall see. I am still interested in learing the correct paint on some items myself. As I have been painting things to match what it looked like when I cleaned it up. I am painting some things to look like bare steel and some things black. As I have learned some of the items may be the other way around. I wont be 100% correct on all things but, I wasn't watching them build me car in 74 either. Bub
1974 400 4 speed |
