Who makes the best piston ring?
Who makes the best piston ring set under $400? I personally am leaning toward the Childs & Albert ZGS (zero gap second) ring set. My engine builder has used them many times in the past with excellent results. (Mostly SBC & BBC engines)
IA2 Block / 4.35 Bore / Ross Custom dish I received a set of Total Seal rings (CR6490 35)with my rotating assembly but it is not a true gapless ring so I'm switching to something different. Anyone have experience with the C&A ZGS ring set, or want to recommmend another high quality gapless ring set?
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ Last edited by R 70 Judge; 12-23-2006 at 02:50 AM. |
Talking to a class racer (400 Firebird) at Mission Raceway a couple of years ago. He said that they had changed to C&A ring packs and were very happy with the gain in et they experienced.
"For some reason a glaze passes over people's faces when you say "Canada". Maybe we should invade South Dakota or something." |
Yes, CR6490 35 is Total Seal's 'Classic' style ring set (not gapless). I have no personal experience with them.
You're sure to get lots of controversy on this question- there have been many posts here about dissatisfaction with gapless rings in Pontiacs. In my competition-only blown/unblown-alcohol engines, I was happy with the performance of Total Seal's gapless-second-ring sets, with moly-filled top and standard-tension oil rings (1/16, 1/16, 3/16). I chose a similar set for a street engine, but haven't yet run it. I have run their gapless-second-ring sets in two Kohler garden tractor engines for about twenty years now, and am very happy with them- other than the electric-start one doesn't want to crank very well! |
I ran the the C&A ZGS rings in my 400 and was very pleased.
My new motor is getting a C&A ZGS ringset.
I've run both the C&A ZGS and Totalseal gapless with excellent results. Current comination has Totalseal.
I don't want to hi-jack this thread but if I may bring up a question. Can you sucessfully run the gaples rings without running a vacuum pump? When we talk about gapless rings are we talking low tension or standard tension rings? Thanks.
Tim C
Tim Corcoran |
I've run both C&A and Totalseal Gapless rings and been happy with both. As for who is best, I run both types in the same engine to know. But leakdown test have shown no regonizable differences. As for running without a vacuum pump, yes you can, they excel with the pump. Some claim high rpm flutter without a pump, but we never had that issue. Ringland placement can make a difference though.
I never use or install gapless rings in any of my engines. Also the trend in the last 5 years is to run more gap on the second ring than the top ring. Why do you think that is???? It is because the pressure between the top and second rings needs to be ZERO, or the top ring seal will suffer. A traditional speedpro ring set is still one of the best choices. The stainless oil ring is second to none.
Ring choice
74ta.I agree with you.I have never run gapless rings and had great success with file fit sealed power sets.I have not tried the larger second ring gap however.Is there more power or just better ring life??
70 Judge, Don,t laugh but im hearing Hastings has a great set of rings
Jegs is having a sale on the Childs & Albert 4.38" bore ZGS rings right now. It's the wrong size ring for me, but I figured I'd pass it on. http://www.jegs.com/webapp/wcs/store...19349_-1_10221
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
Hastings makes a decent ring set. The oil ring that TS uses is sometimes from hastings.
I like the Hastings top ring. It has a bevel on the inside upper part of the ring that twists the ring upwards against the bore. On the power stroke, combustion pressure forces it down so that it is perpendicular to the bore for good seal. On the non-power strokes, it twists up & forms a sharp edge to scrape oil off the bore. The good thing about it also is that as it wears, the sharp edge remains & will continue to work for the life of the ring, & not go away after xx,000 miles.
As they say, it all depends on the application !
Some of the more popular "name brand" rings are actually made by Hastings.
Tim C
Tim Corcoran |
rings
im using hastings power flex .BB chevy file fit 'using J.e pistons.good combo
I know it's not one of the choices, my pick is Speed Pro file fit rings. They are inexpensive compared to zero gaps and perform as well or better in every case I've encountered. Hastings is another popular choice in the shop where I work. Alcohol and supercharged applications have different requirements than naturally asperated. Those applications the zero gap has merit. |
