89 GTA Rear End Swap - Will discs swap? HELP!
Greetings! I have a friend who has an '89 GTA that has a Borg Wagner 9 Bolt set up - it's toast! We've found a rear out of an '87 T/A that is a 10 bolt and has a little lower gear ratio, HOWEVER, is has drum brakes.
My question: If we install th 10 bolt rear, will the disc brake set-up from the '89 fit on the '87 rear? An accurate answer is greatly appreciated. Thanks! |
No, The drums use 3 bolts to attach to the housing and the discs use 4.
Steve M Red '65 GTO,350/350,12bolt,N2O. I got the only beater goat in town, Insured+cruisin' And a couple wee trucks L79 327 5spd S10 Vortec 355 5spd S10 4x4 DD'er |
