Hello.
I have a 64 Lemans in Saddle Bronze. I have the following: 14X5 Pontiac Steel Rims which I had painted Saddle Bronze as well. Pontiac Poverty Caps BF Goodrich black wall tires. Looking to achieve the following look w/o the red lines. (see attachment) I need to purchase lug nuts and value stems. What would you recommend along those lines? Please let me know. Thank you. |
Regular lug nuts and valve stems - nothing special.
The lug nuts are hidden behind the poverty caps, so even used lug nuts would work fine (assuming they aren't stripped or rounded off). If you want/need new, most parts stores will handle stock style lug nuts from Dorman, and they only cost a buck or two each. Valve stems are normally replaced when you get the tires mounted. |
The Following User Says Thank You to The Champ For This Useful Post: | ||
Do the standard Pontiac 14x5 rims have a .453 rim hole or a .625 rim hole for the valves?
.453”
thank you!
Thread Tools | |
Display Modes | |
