Wilwood Rear Disc setup
Just bought Forged Dynalite Pro Series 140-11008-d For my fronts. I'm trying to find the correct part number to match the rears. Thanks.
There are a bunch of different fronts. The old typical was Dynalites with a 10.75 rotor -what I have on the IA/Camaro. They now has a 12.19 dynalite as well as a Superlite caliper with a bigger pad. Dynalite pad is kind of small from a front to me.
i have a fairly brand new rear set if your interested only on car for a few months
My fronts are Dynalite Pros 140 -11008-d's...looking for the corresponding rears..I want to get away from the factory rear calipers..
So did I, the ebrake was very poor. I now have the 11.6" S10/Blazer setup with the drum in hat ebrake and have been very happy with it.
1979 TATA Extreme TKO .64 Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry |
Very easy to upgrade to 12" from S10.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
As long as piston size is the same(front to rear) on the dynalites should be OK. I'd just T the fronts(or use a line lok as a T) and an adjustable prop valve in the rear line.
I'm using the Forged Dynalite Pro Series rear brake 140-5236-B on the rear.
12.19" rotor I run a 15-inch wheel but they note to check the wheel for clearance to see if they fit your specific wheel. .
I have the wilwood 12.19 brakes front and rear with 15" wheels all around.
Thanks guys...looks like I'm just doing the front this year. I have had a bit of an engine issue that I need to resolve first.
Thread Tools | |
Display Modes | |
