Working on re-hashing my four cylinder hemi Pontiac as a two-cylinder, after severe detonation destroyed cylinder #2. Main web #2 of the aluminum block got beat up and needed cracks TIG welded, so #2 main bore ended up out-of-round. #1 & #3 bores are okay, so I employed my pseudo-align-bore contraption to make #2 round again at .030" over, so I'll use .015" brass shim stock behind the bearing insert (the #2 main cap survived without distortion).
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
Jack I think the plasticity of Brass will not stand up to the loading .
Maybe if there big enough so they can be cut down how about two .015" feeler gauges?
Looks good Jack. Where there's a will, there's a way.
![]() Quote:
The Following User Says Thank You to hurryinhoosier62 For This Useful Post: | ||
The mandrel is 3/4" diameter chrome moly and does not flex. It's a precise fit in the carrier blocks- would bind if not well lubed. With such a short tool bit, no chatter cutting cast aluminum up to .004" deep- I usually only cut about .001" deep, rotating the feed screw very slowly by hand.
The Following 3 Users Say Thank You to Jack Gifford For This Useful Post: | ||
![]() Quote:
![]() Quote:
Stan
Thread Tools | |
Display Modes | |
