this is in a 1971 sport Lemans Is there any secret to keep the dash lights working. I pulled the dash and replaced the bad bulbs and in less than 2 months some are not working again. do I need to use some conductive grease or sand contacts.
Maybe a bad connection with the bulb socket or the oil on your fingers got on the bulb and overheated the bulb.
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. ![]() |
Chinese bulbs?
if they are 194 bulbs, make sure the prongs are pulled apart before putting in
could be oils from your hands corossion bad circuitry etc... i relaced mine with some new 194 silverstars, slightly brigther then the standard 194, but not to brite had to pull 1/2 of them and pull the prongs apart further once i did that, perfect |
The plastic sockets often to not contact the printed circuit with enough tension. That or your printed circuit is bad.
I always test each socket with a bulb inside before I mount them, 1/2 the time they will not light and I find that I have to play around with the brass "tangs." The trick it to get those to touch the bulb's tiny wire twines with greater force.
Peter Serio Owner, Precision Pontiac |
Thank you for the advice I have one more cruise left to go to this Saturday then I pull the dash out again.
"CAUTION: The retaining screws are part of the grounding circuit and must be installed to provide proper connections for the printed circuit" this was taken from 12-17 of my shop manual. im pretty sure i left off a screw or two from mine and have been having lighting issues since. i will be pulling the dash and fixing really soon
Thread Tools | |
Display Modes | |
