Old 03-19-2024, 08:10 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Default Horn
WTB driver side horn.
  #442
Old 03-20-2024, 04:30 AM
Drag Star Le Mans's Avatar
I have a few and will function test. Do you need a year specific or just functioning?
DragStarLeMans
  #443
Old 03-20-2024, 07:37 AM
PLongen PLongen is offline
Default 63 Power Steering Pump Pulley Wanted
Looking for a 63 LeMans power steering pump pulley.
Specs for the pulley would be good too.
Than you,
Pat
  #444
Old 03-20-2024, 05:36 PM
hobbygto65's Avatar
I'm kind of wondering now, the horn was for my 63 Lemans but now after looking at my wiring diagram it only shows one horn on the passenger side.
  #445
Old 03-26-2024, 03:50 PM
deanremix's Avatar
deanremix deanremix is offline
Still looking g for fenders and quarters for a 61 tempest if anyone has a bead on some lmk
  #446
Old 04-13-2024, 08:16 AM
Found pulley
thanks
  #447
Old 04-24-2024, 09:25 PM
Apsesia Apsesia is offline
Default Rear end
Looking for a or higher gear ratio rear end for a 1963 lemans. Have a 2.91 in the car now. Have found a 3.30 but was wondering if anyone has any higher. Car is a 326 auto I am in Mooresville nc so if close even better.
  #448
Old 04-24-2024, 09:45 PM
tom s tom s is offline
They did make a 3.90 gear,had a set in my 63HO car I bought new in 63.I think pretty rare and takes a diff carrier as I remember.Dont know what uother gears were inbetween that required a dif carrier.Tom
  #449
Old 04-25-2024, 05:52 AM
I believe they also had something around a 3.55 and 3.78. Those 3 seem to all be harder to find. I’ve seen a bunch if 3.09.
  #450
Old 04-25-2024, 09:01 PM
firefour1 firefour1 is offline
Default PS Bracket
Originally Posted by PLongen View Post
thanks for the pictures that helps. All need now is a templet to make the front bracket. It shouldn't be to hard.
Pat
Have attached the photo of the entire assembly. The two black ones are needed, the other two are part of the alternator mounting. Flat plate in the front, angled part connects to the motor mount bracket. The PS pump is fixed in place, the belt is tensioned off of the alternator adjustment. Let me know if there is anything else needed.
