Old 03-07-2024, 01:20 AM
Formulabruce's Avatar
Default repop Glove box door fit
Been working on my Buddies 70 formula and I factory style rivited a repop plastic "shell" on the original glove box door frame . It looks way warped on top edges and the holes for mounting the hinge had to be elongaed, and Im still not happy. I had to change a few under warranty way back, but this fits worse.. Pics soon. Anyone used them? TY, FB
Old 04-10-2024, 11:38 AM
unruhjonny's Avatar
I didn't know that the glove box door front face was available - did you have to buy a repop door assembly, and remove the front off?
1970 Formula 400
Old 04-10-2024, 12:37 PM
No, they only offer the glovebox face, not the whole assembly.
I bought a 2nd dash, 'minor' flaws when recovered, and the gaps on the edge of the glovebox door are pretty big.
Eh, it is what it is, should have compared by fitting the original door assembly on there, but didn't think about it.
My GTO dash/glovebox door was the same way, gaps too big, it was a first run, but by the time I got it all together it was too late to do anything about it.
Old 04-10-2024, 08:06 PM
Second Gen Complete Glove box door, minus lock and stop limiter arm are available now correct for 71 and up. I have Not seen, or tried one. I think I saw it at Firebird central, but not 100% on that. I was trying to get a 70 cover to fit better
Old 04-10-2024, 08:25 PM
Dang, I'm going to have to search that, thanks!
Old 04-10-2024, 10:41 PM
unruhjonny's Avatar
can someone offer a link or tell me where to look for the covers?
i have some spares, and i did find another good ‘70 to replace mine - which got scratched at some point in the last while;
but it would be nice to replace the cover on my original.
1970 Formula 400
Old 04-11-2024, 05:42 AM
Held for Ransom's Avatar
Non-AC - https://www.firebirdcentral.com/70_8...p/das-2124.htm
AC - https://www.firebirdcentral.com/70_8...p/das-2125.htm
So, the '71 which had the same dash texture as the '70 dash, had the glove box door texture like the later dashes?
So long, farewell.
Old 04-11-2024, 06:25 AM
Pricey, but very nice it's available!
Old 04-11-2024, 06:31 AM
Only available in black. Still nice it's available!
The covers only are available in colors, did one for a friend with a red '80 T/A. It's nice not having to dye them.
Old 04-11-2024, 09:27 PM
Mike, the inside metal structure is unique to 1970, which takes a small tire sticker on the right side. So the Frame is unique. The cover with hinge fits them all. The texture in the cover is same as my 72. It is not an exact match to a 1970, but neither are the recovered dashes, from anyone.
F28 is current, you can get one free on the Ames website. Download, OR a free softbound catalog mailed free in the US. ,$10 USD outside the USA.
Old 04-11-2024, 09:17 AM
unruhjonny's Avatar
where is the front face offered through?
1970 Formula 400
Old 04-11-2024, 09:23 AM
Ames, see attached pic...
Old 04-11-2024, 10:03 AM
unruhjonny's Avatar
Thank you for that - yours must be a newer catalog;
mine is an 'F22' - what printing is yours?
1970 Formula 400
Old 04-11-2024, 10:06 AM
It's an F28, not sure when I got it. But I bought the last door prob 2-3 years ago.
Old 04-12-2024, 06:20 AM
Didn't even realize that was inner and outer when I posted, I was focusing on the price which I thought was high. Now I see why you're calling it 71-up (which I'd call '72-up).
So long, farewell.
Old 04-12-2024, 09:16 AM
unruhjonny's Avatar
forgetting the fact that the repop is manufactured for more retaining rivets than 1970;
has anyone compared the shape/perimeter (side by side and atop one another) the repop cover vs an original one?
if the gaps are bigger, that must mean they are smaller(?)
1970 Formula 400
Old 04-12-2024, 09:29 AM
Wish I would have compared, but I prepped the door before I got the dash, and the old cover was trashed, so I pitched it.
Old 04-13-2024, 10:20 PM
I have installed a repop glove box door " cover" from Ames with the 2 extra drilled holes for the newer, more rugged frames 72 ish , up. I used factory 1/8" rivets. The upper right seems curved out a little more than it was. All 3 parts were sent to Al knoch, so the black would all match ( sem is what they use) . The dash was a horror show for fitting anything into it. Way to much foam used on areas that had none originally. This is on a 70 Formula
Old 04-14-2024, 08:04 AM
The foam around the instrument area on mine had too much foam and makes it difficult to install the instrument bezel.
The stereo area is the same way, had troubles installing the bezel.
The top leading edge is also wavy and is so tight against the frame some areas look like the frame may pop through.
The area where the lap/column cover is, is kind of puffy and not very 'square' to have an even gap around the cover.
Some of the corners are not shaped properly.
These areas are the same on my 70-72 A-body and the F-body dashes. So maybe it the process?
Both still look better than the cracked up and faded ones that were on there before, but for the money, one would think they should be near perfect.
