This winter I'm working on upgrading my hood tach area. I'm having my tach face redone and am adding a repo decal and LED bulbs among other things. I would also like to add the plastic push-in holder to my wiring harness and drill the corresponding hole into my hood bracing. Just like it's diagramed in the factory schematic.
I bought my repo hood tach harness many years ago when I added the factory Pontiac hood tach to my car. There's no push-in tab in the harness. Do the current harnesses have the tab? If not, are they used elsewhere on the car or is there a source where I can get one. |
Back in the 1990s I acquired a battered and bent GTO hood that had a factory stamped hood tach hole. I brought it out recently and looked it over. I was curious to see if it had a drilled hole for the wiring holder. Yep.
![]() Quote:
My original DOESNOT have a hole in the hood for that wiring clip. I have both metal clips for the wiring harness like you have pictured but nothing else. Not sure whether that hole and clip was a 70 only deal because in that year GM had a vacuum hose to the hood tach not found on the 69 cars!! |
Hey Jack, that is interesting that your 1969 Judge does not have a drilled hole in the hood. The schematic was from a 1970 assembly manual, maybe like you said, the 1969s just didn't have it. I also wanted to find out what type of fastener went into the hole. I believe it was some type of plastic item. Maybe something close to the plastic dash wiring holder that I have pictured with this reply.
So it's all kind of a mystery. Was it in the schematic but was never done that way on the assembly line? I also dragged out my original Orbit Orange Ram Air hood (kinked on both sides). My car did not come with a hood tach, but I was curious to see if Ram Air hoods also had the hole even if they weren't equipped with a tach. Nope. Last edited by da judge; 05-27-2023 at 06:54 PM. |
Due to condensation, my old dash face had become rusty. And years ago I had painted the badly faded red line tape stripe. R/C Tach Shop rescreened my original face for very little money and it looks good as new.
The Following 3 Users Say Thank You to da judge For This Useful Post: | ||
Rich,
My carousel red 69 Judge I bought in 1973 with a hood tach didn't have that clip either if I remember correctly! That was a pattern car with no glove box emblem. Just wondering if someone other than the factory drilled that hole and installed that clip? Something we can discuss in person this summer when I see ya!! Take care!!! |
Rich, My early build 70 Judge has the push pin hole in the hood for the plastic wire harness retainer that you show in your pics, and it was not an original hood tach car.
Jason |
Wow, seems to be hit or miss. Maybe it was specific to certain plants. For what it's worth, the Vedoro Green hood I showed at the beginning of the thread with the drilled hole came off a 1968 (still sitting in the junkyard to this day). I then have a photo of a hood tach from a mostly original Carousel Red 1969 Judge. No hint of a hole there.
The Following User Says Thank You to da judge For This Useful Post: | ||
