Full Size
For pics and/or info please:
A. Refer to the item number B. Text me at 908.208.7778 the pics are easier over text them here and are more detailed. But I can load them on this post ... BUT CANNOT SEND PICS ON THE PRIVATE MESSAGE BOARD Shipping is from metro Detroit ... p/u is free as always! 1. (3) 1958 NORS Pontiac Tail light lense. 2 have the NORS trim ring.* Glo-rite $50 for all 3. 3. 1966-1965 Full Size (except GP) Vent window reveal molding passenger side ... nice condition $20 4.* 1951-52 Pontiac NOS gauges.* 2 water temp and one alternator ... $30 for all 3.* Use for your hot rod! 5. 1965-68 full size Auto Console Shifter gate slide.* $10 9. NOS Pontiac 63-74 condenser and rotor $12 10. 1966 Full Size NOS Pontiac Bumper* Stop Package front wheel (2) $15 each or $25 for both **13. Gas tank ... I'm told 1967/68 full size ...* you determine!* Comes with sending unit.* $50 **14. 2 Rally Wheels 15×6. 5×5"* KY code 1971.** $150/pr 21. Pontiac original v8 engine lift hook tab. Shaped different than repops.* $10 22. 1965-1966 Full Size Pontiac original speaker.* Needs restored. Part #7300614* 1966-1972. $20 32. Pontiac 2 used Pontiac Neutral Safety/backup switches.* For Automatic transmissions. See pics for condition.* Part #1993448 and #1994153. $15 each 47. Pontiac NOS upper beam headlamp.* (2) $10 ea. 51. 1965 Pontiac, Chevy, Olds, Buick, Caddy New Repop Convertible Pillar Post weatherstrip. $50 62. Carter 4bbl Choke pull off. New.* $15 69. 1968-1975 NOS Pontiac Circuit Breaker $20 70. Pontiac NOS glove box cylinder $40 71. Pontiac NOS 1969-1975 case and rotor glove box lock $20 80. 1967-1975 Pontiac NOS power trunk button mounted in glove box.* Pontiac used green originally.* Repops are yellow.* $125 Another one looks like NOS but has no box.* $90 86. 1969-1972 GTO/GP NOS switch and harness for glove box light.* MINT $50 91 O. 1967 Bonneville Qtr Rocker Moldings L/R 34.5" top measurement. $100 108. 1965 Pontiac Bonneville NOS molding Fender to rocker panel cover #9777372 $50 117. 1966-1972 Pontiac Radiator Cap. USED!* Restore and use.* $10 120. 1966 Grand Prix Parking lamp assemblies.* L/R. No lenses.* The cups have light pitting.* The bezels are excellent.* The harnesses look too be excellent.* The inside cup and gaskets are there.** $75 121. 1966 Full Size Dash Clock.* Not Tested ... as is ... $20.* Tested, Cleaned, Guaranteed working $125. 122. 1965 Pontiac NOS Moraine PB repair kit $40 *123. 1966-1972 Pontiac Radiator Cap.* Box marked NOS but I'm not sure by looking at the back.* In great shape however.* Nothing worse then seeing the wrong radiator cap on a classic Pontiac.* $95 124. 1965 Full Size headlamp bezel specialty screws and washers. New. 8 per set.* Limited quantities ... $25 / set 125. 1965-1966 Pontiac Full Size. Interior door handles.* 3 driver, 2 passenger driver quality.* $20 for all 5. 126. 1969-1970 NOS remote mirror bezel.* Mint.* Show car worthy.* $250 127.* 1965-1966 Pontiac Full Size set of used original window cranks. Nice driver condition.** $20 for the set. 131. 1967-1970 Pontiac aluminum alternator bracket. #9786903 Just clean.* In good condition.* $40 **134. 1965 Full Size? Bucket Seat Chrome Trim.* 11 pieces.* I believe 1965 full size but you check them out and determine.* $100 for all 11 pieces.* **150.* 1965 Pontiac Full Size 421 #76 Heads* $150 **161. 1966 (65 too?) Full Size inner Fender wells.* Powder coated.* One absolute mint.* The other has a quarter size damage due to over powered sandblasting ... might not be seen when installed.* Totally usable.** $200/pr **162. 1969-1972 Grand Prix 4 speed Console.* Complete with ashtray.** $2500 165. New Valve Stems with caps.* (15)* $15 for all 166. New Gaskets Various (14)* $15 for all 170. 1965-1971 Pontiac NOS #9797235 license plate door.* $45 174. 1966-1974 Pontiac outside mirror mounting pad.* New.* (2) $10 each $15 for both *1974-1974 Pontiac shoulder belt esctchuon NOS. #9691094* (3) $10/ea or* $20 for all 185. 1993-up GM Antenna Adapter Cable Kit. NEW.** $5 186. 1971-1973 Pontiac Switch. Steering Column Shift. NOS #546610 $20 188. 1963-1979 Pontiac Door Lock Knob and Shaft. NOS. #9632427** (2)* $50/each or $75/pair 189. a.1969-1970 GTO key buzzer switch. with tilt. #7804514* NOS. $45 b. 1969-1975 Pontiac key buzzer switch without tilt NOS* $45 190. 1976-1980 Pontiac #6270752. NOS Stabilizer Bar Bushing (1)* $5 191. 1970-1972 GTO/GP #9794835 NOS Ring Gear Bolts. 10 for $100 **192.* 1965-1966 Pontiac Full Size.* Brake Drums.* Used.* Good condition.* Rear.** (2) $125 for the pair. **193. 1965-1966 Pontiac Full Size Complete Steering Linkage including Idler Arm.* Used.* Original.** $100 (I have 2 sets) 194. 1965-1966 Pontiac Full Size Deluxe steering wheel horn bar. Very nice chrome. Used.* #9778990 $40 195. 1965 Pontiac Full size hood spear.* Used.* Very nice chrome.* No pits. #9779402* $75 196. 1965 Bonneville Fender emblems.* Very good condition.* No pits.* Used.* Original.* $125 for the pair.* 197. 1966 Pontiac Ventura Quarter Panel* emblems.* Good condition.* Used.* Original.* No pits. #7595044* $40 a pair. 198. 1957-1974 Pontiac Distributor Cap.* NOS in original box.* Delco-Remy not embossed.* #1971244 (2) $40 ea 199. 1965-1972 Pontiac remote mirror cables with eschteon, bezel and knob.* All NOS. To upgrade or repair your remote mirror.* #9780181. $90 200. 1965-1968 Pontiac remote mirror.* Good condition.* Very minor pitting.* Glass great.** Used.** Complete.* Working.* $100 201. Outside mirror.* Don't know the origin.* Great condition.* $35 204. 1960's-1970's MSD Pontiac Distributor Cap New.* Red.* $45 205. 1965-1966 Pontiac Full Size rear seat filler panel to package tray.* I believe it came from a 1965 Bonneville.* You please verify.* Light blue.* $20 206. 1965-up Pontiac Hood insulation clips.* Plastic. (6) for $6 207. 1973-1976 Pontiac RC-33 Radiator Cap used.* Very nice chrome.* $5 208. 1968-1969 (?) Pontiac Catalina letters.* $5 ea.* $10 for all 6. 209. 1965-1968 Pontiac remote mirror.* No glass.* For parts.* Base chrome excellent. The mirror cup will look great with a good polish.* If it doesn't sell Ill take apart, clean, and sell parts individually.* $40 as is. 210. 1969-1975 Pontiac M.T. backup switch NOS #6270695* (1)$35. (1) $50. 211. 1967-1972 Headlight Switch Knob/Shaft with bezel.* Bezel is definitely repop. Just assume the knob/shaft is also. $20 212. 1965-1970 Pontiac Water Thermostat neck.* #9779072 Orig GM.* Needs clean and paint.* (2) $20 ea. 217. 1967-1970 Pontiac power steering bracket. With attaching Bolts and washers.* #9786903 Mint $80 218. Misc. A. Pivot, swivel bracket. B. suspension bumper. C. Hinge brackets. $10 ea. 219. New Repop lock cylinders with keys.* Looks like (1) glove box/ Console from mid-late 60's and (1) door/ Trunk. $20 ea or $30 for both 220. Gasket used. can't read number but it's for LH side.* U decide* $5 221.1971-1974 Pontiac bullet style mirror bracket.* New.* Repop.* $10 222. Gasket unknown $5 229. 1969-1970 Pontiac NOS Defogger Motor.* #4919550 mint with harness.* $75 240. 1967-1972 Pontiac manual Trans Shifter boot.* NOS #9795407 $195 241. 1970-1972 GTO, Pontiac Convertible map light rearview Mirror.* Great condition except for the glass.* Comes with the mint mount and cover.* You can have new glass put in four $15-20.* $100 253. 1971-1973 Pontiac Steering Column shift knob switch NOS $35 256. 1960's-1970's NOS Water Temperature Switch for cars WITH gauges.* A/C Delco G1852 #12334869* $35 257. 1957 tripower, 1963-1964 421 tripower H.O. & SD, NOS Oil Breather Cap with H.D. air cleaner.* (Also for 64-67 Vettes)* #6419440 $50 261. 1968-1971 Pontiac Gear Selector housing, automatic console #9792136* excellent condition original GM. Rare. $50 262. Convertible top hose (1) $15 263. Glove Box/Console box lock cylinder.* $10 266. Used Chrome lug nuts.* 4 have a black tip on the top.* All are 7/16 × 20.* (10) $20
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console 1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats 2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather |
