WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 2004-06 GTO Owners > 04-06 Engine Tech
04-06 Engine Tech LS engine tech center. Get the most out of your car here.
Old 05-13-2011, 02:19 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Default Ticking sound from under hood
I have a 2006 GTO with 14K miles on it and have started hearing a sound from under the hood which sounds like valves ticking. Has anyone experience this at such low miles? I have never had it up to the red line and usually shift prior to reaching 4000 RPM's although I have had it up to 5000 RPM's a time or two, or three.
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 05-13-2011, 02:12 PM
Verdoro 68's Avatar
LS2s (and LS engines in general) are notorious for the sewing machine-like valve train clatter. Are you sure it's a new sound?
That said, I have heard a lot about oiling issues with LS2s - primarily oil pumps giving up the ghost - so it's feasible something could be going on.
Can you give more specifics on the sound? Does it sound like one valve tapping or is it a consistent clattering? Louder/more frequent with more RPMs or always the same?
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around)
Old 05-13-2011, 04:43 PM
verdoro 68-
Thanks for the reply. I just started noticing it a few weeks back. I do not drive it very much, and first noticed it on the Hwy on a stretch that had a concrete barrier. I had the window down while the A/C was getting up to a good cold Temp. It was a very faint ticking sound. When I got home I let the window down and listened, it sounded like maybe one valve might be making the noise. I will check out what you recommend and let you know what I find out.
1976 Formula 350.
1968 Olds 442.
1971 TR6.
Old 05-13-2011, 09:43 PM
PontGuy's Avatar
PontGuy PontGuy is offline
I bought my 06 new and the valve train has been a bit noisy since I first drove off the lot. No different after 50+K miles. I notice it when the engine is running in the garage and at drive-thru windows and such, but can't really hear it otherwise. Maybe you are just now noticing it.
Never over 5000 RPM's? Wow, that may be part of the problem! I drive mine nice, but the LS-2 does seem to love eating up highway entrance ramps!
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
Old 05-17-2011, 07:35 PM
Also the injectors cycling make some clicking.
Old 05-18-2011, 01:17 PM
IOWA552SLOW IOWA552SLOW is offline
my 04 (yes i know ls1) has a "noisy" valve train. has since i bought at 28k miles. never any better, never any worse. don't hear it on the highway on when idling. in the driveway or drivethru situations. i was told once that the ls motors are know for noisier drive trains. i have alway thought that mine was noisy. i put an oil pressure guage in mine, carries 40+ lbs of pressure at idle and will hit 100+lbs at full throttle. an actual pressure guage may help put your mind at ease if you know the pressure.
Old 06-01-2011, 09:14 PM
14,000 miles??? The problem is.... you don't drive it enough! 5k rpm??? You aren't driving it hard enough either
1974 Formula 400 - Ram Air automatic
Old 06-08-2011, 03:21 PM
TA-71 TA-71 is offline
My 06 developed that same sound, took it into the dealer and found the cam and flat spotted a lobe. Ended up replacing the cam under warranty.
1971 Trans Am - Sold
1977 Can Am - Sold
2002 Trans Am Firehawk - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
1972 Trans Am - Sold
1970 Trans Am - Current Project
Old 09-12-2013, 03:40 PM
brandont's Avatar
brandont brandont is offline
Pypes & PY Tech
It is typical for the LS motors to have noisy lifters. It doesn't mean they are bad but if it gets worse, then its time to swap them out.
Featured Vendors
Advertising Info
