Old 03-31-2024, 03:35 PM
steve@tru-built.net steve@tru-built.net is offline
Default Exhaust Manifolds
I'm currently rebuilding the engine in my 68 Pontiac Firebird. The car has been in my family since 1972. My grandfather purchased it from his boss who purchase it new. It's mostly original with 68K miles and numbers matching. It's a 320 HP 350 H.O. with 4-speed car. I'm thinking about upgrading the exhaust manifolds. I don't want to go with header if possible. I'm thinking about installing a set of Ram Air III manifolds. I found a set on Ebay, but they're for 68 and 69 GTO. Does anyone know if these will work on a Firebird without issues?
Thanks,
Old 03-31-2024, 03:44 PM
They’re the wrong manifolds and won’t fit the early Firebirds.
You need the long branch style that fit the first-gen Firebirds and 1965-1970 big Pontiacs.
Old 03-31-2024, 05:44 PM
68tpls400 68tpls400 is offline
Look at RAM air restoration manifolds. Just like new, only better.
Google them.
Old 03-31-2024, 06:55 PM
Cammer-6 Cammer-6 is offline
will need the oil filter adapter too
interesting car please provide more details
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 03-31-2024, 09:46 PM
Donovan Donovan is offline
I installed the longbranch manifolds on my 68 350HO like you are considering. The oil filter adapter is odd and will weep oil but overall a great upgrade. Dual exhaust with 2.5 inch headpipes will be a great fit and make the upgrade worth it. They also look awesome when you pop the hood. These make room for future upgrades to shine, like cam updates.
The A body manifolds don't fit and make less power in any case.
Old 03-31-2024, 09:48 PM
https://www.ramairrestoration.com/po...c-coating.html
they also have less expensive uncoated units available.
Old 03-31-2024, 10:09 PM
The Ram Air/HO manifolds might buy you 8 to 10 horsepower at the most on a stock or near stock engine.
They’re a nice upgrade (and really mostly eye candy) but once you’re done you’re into them close to a grand once you buy the manifolds, filter adapter and the down pipes that are compatible.
Simply upgrading your exhaust to 2-1/2” and keeping the original log style manifolds might make more sense economically and will provide a nice boost in performance. PYPES exhaust sells some 2-1/2” down pipes that neck down the first few inches to 2-1/4” to match up with the manifold outlets.
The 350, 400 and 455 engines all used the same standard exhaust manifolds so it follows that the 350 would see the most flow and least restriction from them cubic inch wise.
So the same 2-1/2” exhaust system using both manifold styles might have a 5 horsepower difference. The standard log manifolds really aren’t as bad as most people think. The GTO style and long branch style are very close in performance, there isn’t a big difference it’s just whatever fits your chassis.
Old 04-05-2024, 04:08 PM
rdl's Avatar
rdl rdl is offline
Post
Originally Posted by Donovan View Post
... The oil filter adapter is odd and will weep oil but overall a great upgrade...
I discovered the same thing the first time I installed the adapter. The solution was to torque the interior bolt to 60 ft/lbs (instead of the recommended 30) and use a good gasket sealant. No leaks or weeping.
'69 R/A III Firebird Convertible
14.0s @ 100.8mph AMA/OEM/OER
Old 04-05-2024, 04:51 PM
JLMounce JLMounce is offline
I agree with this. It's probably not worth it on a mostly stock 350 to upgrade to the long branch manifolds.
Another thing to consider that hasn't been brought up here is IF you can get a set of long branch manifolds. RARE hasn't had a complete set available for years. I tried for about 4 years straight to get a set and was always told, "we're having more cast, should be about 6 months."
-Jason
1969 Pontiac Firebird
Old 04-05-2024, 08:05 PM
tom s tom s is offline
I think RARE is shipping D port long branch pretty good now.Its the round ports that are missing.Tom
