So looking for a fault with headlights, low beam has yellow low voltage appearance with the high beam glowing a little.
High beams have a bright appearance, and lows are glowing a little. Found and cleaned earth for Headlight harness. Removed all headlight plugs and spray cleaned with electrical contact cleaner. Open bulkhead main plug ,spray clean and blow dry , reinstall. Cleaned main earth at the engine and battery . The highbeam switch on the steering column sounds bad with a bad sound when switching. The blnker arm can fall off as it's loose. Has no instrument lights and high beam indicator not working Any owners done battle to fix similar faults. I hope I can buy new headlight and high beam/ blinker switches ? Any ideas, John L. Sent from my SM-X200 using Tapatalk
