Old 08-27-2021, 03:51 PM
Cannonball Cannonball is offline
Default 1970 TA center console optional?
Hello all, recently acquired a 1970 Trans Am with black deluxe interior option and 4 speed manual. The car has been previously "restored" and some kind of console put in, with the power window switches in place. Car has manual windows. I have the PHS documentation and do not see anything in regards to the console. Was it standard or optional on 1970 TAs and how would I know if the car came with it? Thank you.
Old 08-27-2021, 07:25 PM
72projectbird's Avatar
The console was an option. My 70 has one, and it's listed on the PHS.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 08-27-2021, 07:52 PM
Brewster's Avatar
Brewster Brewster is offline
Buy a phs
Old 08-27-2021, 08:27 PM
Thanks. Do have the PHS, all that is listed is:
RADIO P/B
BATTERY-HD
ANTI-FREEZE
SPEAKER R/ST
CUSTOM TRIM
Does that mean no console, otherwise it would have been listed as a separate option?
Old 08-27-2021, 09:02 PM
johnta1 johnta1 is online now
Correct.
No console
Old 08-27-2021, 10:30 PM
Perhaps they have slipped one in to to use easily and to cover possible carpet holes that some brands automatically had there. Easy to check if it had factory console mounting brackets, even without the paperwork or window switches.
Old 08-28-2021, 08:47 PM
bird72's Avatar
bird72 bird72 is offline
A no console 4 speed is a definite factory build configuration. Although, I like the place for the right elbow with console, I would put that one back to no console. It is a serious, all business, no fluff look. ****LIKE****
72 Bird
The Following User Says Thank You to bird72 For This Useful Post:
Old 08-28-2021, 10:04 PM
Having seen pictures of no console 4 speed cars, I do like the look also. That also means that I have one less thing to source 🙂 Thanks for the input folks
Old 08-29-2021, 07:00 AM
It may be there for a reason, lift it out for a look.
Old 08-29-2021, 12:51 PM
bird72's Avatar
I also would add that the custom interior with no console is double cool.
72 Bird
Old 08-29-2021, 06:15 PM
Formulabruce's Avatar
Consoles were optional on automatics too ! , even Trans Am's . How is your interior?
Old 08-31-2021, 10:04 PM
The interior looks complete at first glance, haven't dug into it yet though. The dash has a crack on top, and some warping. Door panels look original with the comfort weave inserts, have some minimal waviness on top. Seats are correct but are not wearing the deluxe covers. Steering wheel vinyl is pretty worn.
Old 09-01-2021, 05:41 AM
Judge273's Avatar
Judge273 Judge273 is offline
Not a 70. But, 71 makes for a clean hump
Mike/Illinois
The Following 2 Users Say Thank You to Judge273 For This Useful Post:
Old 09-04-2021, 11:51 AM
Looked under the console and indeed no brackets in the back to attach it to the floor. The bad is that there is a sizable cut out in the carpet in the shifter area so I cannot remove the console without dealing with it. From the last picture there looks to be a separate piece of carpet covering the hump. Is that the case? Can it be sourced from somewhere on its own? Thanks.
Old 09-04-2021, 12:04 PM
Front and rear carpet as were 2-piece in early years.
Old 09-04-2021, 01:22 PM
I have a Lucy Blue 70 T/A with standard blue interior and a column shift. I have a bunch of paperwork from the original owner where he special ordered it. It's my understanding he expected it to come in as a floor shift with no console, but instead it came in as a column shift. He wasn't happy.
Apparently column shift automatic only came on standard interior when you didn't order a tape deck. Ordering a tape deck automatically got you a console, and ordering deluxe interior automatically got you a console.
I've been hanging onto an excellent low mileage deluxe blue interior so I could convert to floor shift.
Old 09-04-2021, 03:55 PM
Norwood's Avatar
Norwood Norwood is offline
Also notice that the console and no console shifter sticks are different.
The Following User Says Thank You to Norwood For This Useful Post:
Old 09-04-2021, 05:45 PM
3 piece...there is a vinyl filler between back seats on the hump.
Old 09-04-2021, 05:47 PM
Transmissions too. I had a 4 speed Esprit with full gauges, deluxe, and no console. As I recall it had A Saginaw 4 speed with Hurst shifter, think the lever was different than for Muncie.
Old 09-04-2021, 10:19 PM
There was no linkage between deluxe interior and console - they were independent options. (The car in the picture above is an example of one).
