Old 07-04-2020, 06:13 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Default 1969 Firebird TA 400 HO/RAIII D-Port Long Branch Manifolds
This item is a set of original GM 1969 Firebird TA 400 HO/RAIII D-Port Long Branch Manifolds.
The manifolds are not cracked, the outer surface is rust pitted to the point where the numbers and date codes are not very legible, and the lower exhaust studs threaded holes were drilled out to accept through bolts.
$500 plus the ride.
PM me if you are interested.
Regards,
Rob
ID:	544277   Click image for larger version
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 08-30-2020, 09:28 PM
RAJ7395's Avatar
All - I re-bead blasted the manifolds and sprayed them with Eastwoods Cast Iron high temp exhaust manifold paint. Afterward, I found cracks in three of the exhaust mounting flange ears.
I can't in good conscience sell these.
No longer for sale!
