Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 05-13-2022, 01:02 AM
quick67bird's Avatar
quick67bird quick67bird is offline
Default 12 bolt Richmond 4.10 ring and pinion gear set
Richmond ring and pinion gear set new in box for a Chevrolet 12 bolt. Part number 69-0031-1. $225 plus shipping.
ID:	590677   Click image for larger version
ID:	590678   Click image for larger version
ID:	590679   Click image for larger version
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 05-19-2022, 12:07 AM
Open to offers bumping on up.
Old 06-02-2022, 11:40 PM
Bumping up
Old 06-14-2022, 11:43 PM
$200 bump
Old 11-07-2023, 12:34 AM
$175 plus shipping bump.
Old 03-02-2024, 06:21 PM
$150 OBO plus shipping
Old 04-26-2024, 02:52 PM
Bump
Old 04-26-2024, 06:50 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Will this fit in a carrier that has 3;23 gears now?
I think it is a 3 series an the 4;10 needs a 4 series?
mine is a 67 Chevy 12 bolt
Old 04-26-2024, 11:58 PM
I don’t think so. It shows on Summit to be a 4 series gear set.
https://www.summitracing.com/parts/RMG-6900311
Old 04-26-2024, 11:59 PM
Old 05-03-2024, 09:39 AM
Pigeon Pigeon is offline
Default 4.10 gears
Hi, one question about your gears if you still have them. In the picture of the back of the pinion, near the bottom, there is a jagged line that looks like a crack? I doubt if it is and if you take a look at it and it’s not a defect or something I’ll take them.
You can txt me directly if you would at 610 405 9177
Old 05-03-2024, 12:33 PM
65gto69's Avatar
65gto69 65gto69 is offline
PM sent
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, TCI Flex plate, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 05-05-2024, 12:14 PM
Sold. Thank you PY and Rich
