Old 10-03-2023, 09:53 AM
ejgoat ejgoat is offline
Default Electric connector
I need a rear lighting harness connector to the ribbon wire for a 64 goat, damaged mine, can,t get in touch with m/h electric to buy one, anyone have one.
Old 10-03-2023, 05:15 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Can you post a picture of it, have some 64 -65 stuff.
But I'm in Canada so might take a while to get there.
64 Lemans hardtop
4spd, buckets
Old 10-03-2023, 09:03 PM
jhnichols2 jhnichols2 is offline
Here are pictures of the rear lighting harness from my 64 convertible. not for sale but may help you find one.
ID:	620945   Click image for larger version
Old 10-04-2023, 10:19 AM
I NEED the black connector on the end of the 1964 GTO rear wiring harness.
Old 10-04-2023, 10:20 AM
i NEED THE BLACK CONNECTOR TO THAT HARNESS
Old 10-04-2023, 01:06 PM
Lemans64's Avatar
Isn't that part of ribbon harness?
64 Lemans hardtop
4spd, buckets
The Following User Says Thank You to Lemans64 For This Useful Post:
Old 10-05-2023, 12:30 PM
iTS THE BLACK CONNECTOR AT THE END OF THE REAR WIRING HARNESS, NOT ON THE RIBBON, IT CONNECTS THE REAR HARNESS TO THE ROBBON WIRE
Old 10-05-2023, 08:02 PM
Photos of 64 Le mans convertible body ribbon harness. Black connector is where rear tail light harness plugs into. Are you looking for a male or female connector?
64 very hard to find and not reproduced to my knowledge. .65 harnesses are reversed from 64. I beleive 65 are reproduced.
ID:	621111   Click image for larger version
ID:	621112   Click image for larger version
Old 10-05-2023, 08:25 PM
Lemans64's Avatar
Not sure which connector you are looking for. Sorry for any confusion, But is the connector by the fuse box or by the rear seat? The dirty connector is on taillight harness at or under rear seat area. Clean connector is at fuse box location. Both of these plug into black connector on ribbon harness.
ID:	621119   Click image for larger version
ID:	621120   Click image for larger version
ID:	621121   Click image for larger version
64 Lemans hardtop
4spd, buckets
Old 10-08-2023, 01:04 PM
Default Ribbon connector
Rear lighting harness wires terminate at this black connector that plugs into the ribbon wire has a hook on each side that connects to the ribbon wire
Old 10-12-2023, 01:09 PM
CONNECTOR IS IN THE TRUNK BEHIND REAR SEAT, ITS THE BLACK CONNECTOR AT THE END OF THE REAR LIGHTING HARNESS THAT PLUGS IN TO THE RIBBON FROM THE FUSR PANEL
Old 10-12-2023, 02:20 PM
Cammer-6 Cammer-6 is offline
so who have you contacted that makes harnesses?
what was your failure in contacting M&H?
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 10-13-2023, 11:57 AM
Lemans64's Avatar
Your connector is not like the post 8 picture? That connector is part of the ribbon harness I believe.
64 Lemans hardtop
4spd, buckets
