Old 08-26-2022, 02:10 PM
abefromen's Avatar
abefromen abefromen is offline
Default Distributor gear
Is the gear on a 70's HEI steel or cast iron?
If a stock cam is cast iron shouldn't the gear be steel?
Confusing topic when doing a web search.......thousand different answers.
Old 08-26-2022, 03:40 PM
25stevem's Avatar
25stevem 25stevem is offline
Pretty easy to tell the difference.
Cast iron will not spark when ground or polished, but a steel will.
I do stuff for reasons.
Old 08-26-2022, 03:56 PM
abefromen's Avatar
I tried that. I put a dizzy gear and a cast iron oil pump casting I had to my bench grinder and had a lot of yellow sparks from both. If the gear was steel I thought it would spark less but it didn’t.
Old 08-26-2022, 05:13 PM
25stevem's Avatar
I think oil pump body’s are cast steel.
Old 08-27-2022, 01:19 PM
tjs72lemans tjs72lemans is offline
They didn't make HEI in 70.
Old 08-27-2022, 03:20 PM
firechicken's Avatar
firechicken firechicken is offline
He said 70's, not 70.
