Old 03-27-2006, 01:00 AM
bracketracer bracketracer is offline
Send a message via MSN to bracketracer Send a message via Yahoo to bracketracer
Default oil pressure
is a 100 psi oil pressure to much in a warm pontiac race engine with a roller cam??????thanks.....ryan
Old 03-27-2006, 02:42 AM
02Hawk's Avatar
02Hawk 02Hawk is offline
I would think so. I would first check the guage and then how and where it;s hooked up and where are you taking the reading from.
What kind of pump are you running?
60 lbs is lots
Old 03-27-2006, 05:31 AM
melling race pump 10541
Old 03-27-2006, 05:32 AM
i ordered a oil pressure test gauge.....i will try it this weekend
Old 03-27-2006, 08:35 AM
hal101's Avatar
hal101 hal101 is offline
what temp ?
what rpm ?
what wt oil ?
100 psi will not hurt anything but may ware your dist gear
check pressher at the dist
make sure you don't hav a cloged filter
Old 03-27-2006, 08:30 PM
WDCreech's Avatar
WDCreech WDCreech is offline
I ran a Titan pump in my 474 race motor and when first fired pressure went way past 100 lbs until it warmed up. Everything in that engine looked perfect. The only problem was too much horsepower. The block was starting to split. If it wouldn't have been, I would have reused everything except for rings.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08
Old 03-27-2006, 08:56 PM
RAIV55 RAIV55 is offline
Personally, i wouldn't care for that much pressure. My bearings look great with 1/2 that much in a roller 455 that's making close to 700HP.
Old 03-28-2006, 08:15 PM
Jeff V Jeff V is offline
I like 65-75lbs max.
Jeff Verdi
2016 Spring Fling Million Winner
2016 CARS Million Winner
Old 03-29-2006, 11:49 AM
rumair rumair is offline
i have the melling pump in my 474 race engine. taking the reading from the filter housing i used to see 70-75 pounds warm. this winter i relocated the oil pressure line to the hole in the block next to the distributor. i was told to expect a ~10~ pound drop in pressure from making this change and that's exactly what i've seen. i run royal purple 20W50 oil.
Old 03-29-2006, 06:05 PM
My firend using a 80 lb Mellings motor saw over 100 on the dyno when it was at 6200+
Old 03-30-2006, 01:35 PM
i saw 85-90 pounds on the chassis dyno at 6500.
Old 03-30-2006, 06:39 PM
Probird's Avatar
Probird Probird is offline
Mine will read over a 100 going down the track. Reading is taken by the distributor. Had it apart this winter and everything looked great. This will be the 3rd season on this set of bearings.
Old 03-31-2006, 12:15 AM
these are with the engine temps at 160 degrees 20 w 50 oil and 6000 rpm
Old 03-31-2006, 12:18 AM
Probird's Avatar
I quit using the 20w-50 oil. I've been using 5w-30 synthetic. That lowered the pressure quite a bit.
Old 03-31-2006, 01:18 AM
how long does it usually take to break an engine in enough to use synthetic oil???
Old 03-31-2006, 08:43 AM
hal101's Avatar
how much pressure when at 1000 rpm 160 degrees ?
Old 03-31-2006, 03:42 PM
at 1100rpm (idle) it has 80 psi
Old 03-31-2006, 04:33 PM
fasteddy's Avatar
fasteddy fasteddy is offline
Put in a lighter synthetic or blend like 5w30 and you will see a performance increase. Do it next outing-should be fine.
fasteddy
Old 03-31-2006, 07:07 PM
Billy177's Avatar
Billy177 Billy177 is offline
i put synthetic in after 500 miles
Old 03-31-2006, 07:16 PM
"Puddles the Pontiac" "Puddles the Pontiac" is offline
Send a message via Yahoo to "Puddles the Pontiac"
i don't know if this was mentioned, but most engine builders i have spoke with say to keep about 10lbs per 1000rpm. anything else, though it may not hurt your engine, is a waste. you will lose hp with excessive pressure. i like the ideas of lowering the pressure with thinner oil. i may quit using 15w50 myself.
