Old 05-12-2024, 07:25 PM
kpbrown31 kpbrown31 is offline
Default TH400 to 4L80e tunnel size accommodation
I've searched the forum and can't find someone swapping a 4L80e into a 65 or 66. My 66 Catalina has a 400 in it now. I always assumed the 400s and 4L80es were of similar size in terms of case dimensions. I know the 4L80e is a little longer. I'm just curious if anyone has done the swap, and was raising and/or enlarging the tunnel needed? Thanks
Old 05-12-2024, 10:02 PM
Sirrotica's Avatar
Almost any GM car that came with a T 400 in it, will accept a 4L80E. The closest interference point is the rear most cooling line in the 97, and later transmissions. Using a 91-96 case moves that line back to the same area as the T 400.
There are aftermarket fittings for the 97, and later cases that minimize the rear line being close to the tunnel if you end up with the later style case.
Contrary to what gets posted on the internet, there are only a few GM bodies that need anything more than occasional tap with a hammer to allow the 4L80E to fit, most tunnels require no modification whatsoever.
The early 60s full size cars that came with the Roto hydramatic, 61-64, do have a narrower tunnel that might require some stretching.
I hope that helps you out.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 05-14-2024, 03:35 PM
I like the sound of this! I was actually looking for a later model case to have the split cooler lines for improving oiling, but I honestly think unless you’re running the transmission hard (which I’m not at all) then the early style is just fine. From what I’ve read a good builder can compensate for that anyways and you’ll be just fine. The older styles are easier/cheaper to come by anyways. Thanks!
Old 05-14-2024, 04:45 PM
GTO JONES's Avatar
GTO JONES GTO JONES is offline
I do know 4L80E will fit the 69 A body with no problem
Old 05-14-2024, 06:04 PM
Sirrotica's Avatar
I have a 93 K3500 with the early style cooling lines, it finally failed at 280,000 miles.
As Jake, from Jake's Performance, that specializes in 4L80E's has said, he sees no difference in reliability between the early transmissions, and the later design. Although GM contends, they made the change to help with lubrication. There isn't really a lubrication problem that is obvious, and there are millions of early, and late transmissions out in the field. Someone like Jake. that specializes in performance 4L80E's would have seen a problem, if there was one.
If all things were equal, I would have no problem choosing an early case to simplify routing cooling lines.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
