View Single Post
Old 04-23-2021, 07:43 PM
Steve C. Steve C. is offline
Googled up.... "Once the four timing parameters are established, the cam should be designed for maximum lift."
https://www.tildentechnologies.com/C...rformance.html
"If you want to build a street motor with the most power without a sacrifice of idle and low speed qualities, then lift is the most important factor to maximize, not duration. The best suited cams are those that seek to maximize lift while only adding a minimal amount of duration."
David Vizard
Old information here:
