As far as the shifter issue, I think it has to be a shift linkage issue. I bet the nut[or bolt, depending on which Muncie] fell off, an the linkage rod fell off. Can't think of anything that could possibly go wrong inside the tranny for that issue to happen without the tranny making a whole bunch of noise.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
