Something is causing that low vacuum at idle. I believe that needs to be addressed before anything else.
Not familiar with how your cam compares to the SD cam. If close, then SD calibrations should be a good starting point, but John (61-63) has set up a lot of these. I would suggest starting with his recommendations, but address that vacuum before doing anything else.
How about the compatability of the Offy manifold to the e-heads?
Jon.
