Learning to weld - replace trunk pan?
I’ve done a little welding with my Hobart Handler 140- mainly spot welds which I feel pretty comfortable with. I plan to continue practicing and would like to replace the center trunk pan and a gas tank brace in my 69 bird next winter. Is this typically a very difficult job I should leave to a pro? Any tips or pitfalls?
Using below parts:
https://www.topflightautomotive.com/...IaAlSwEALw_wcB
https://www.topflightautomotive.com/...EaAkaqEALw_wcB
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
