-   OHC-6 TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=496)
-   -   Sprint vs 1bbl parts differences? (https://forums.maxperformanceinc.com/forums/showthread.php?t=870877)
justincampbell 12-15-2023 02:04 AM
Is the head or the crank/rods different between a Sprint motor and a 1bbl motor in '66?
Jeff Hamlin 12-15-2023 06:55 AM
Short Blocks are basically the same.
Cam, Head, Manifolds, Carb.
Cammer-6 12-15-2023 11:01 AM
they did advertised that bearings were upgraded in the 4 bbl
but as Jeff says otherwise identical(also sans balancer)
justincampbell 12-15-2023 05:24 PM
Is a Sprint head or block (ZD) worth much if they need gone thru the machine shop (and possibly one sleeve)?
The mice took up temporary residence in a couple of the cylinders at some point.
Cammer-6 12-15-2023 06:11 PM
Unless its for a number match scenario a block that needs sleeved is worthless IMHO.
TheSilverBuick 12-15-2023 06:36 PM
Pretty much all modern bearing and ring offerings are superior to 1960's OE parts, so isn't a real consideration when comparing the 1bbl to 4bbl today. Pistons, crank, rods and block are the same.
Outside the obvious intake/exhaust manifolds, the cylinder heads and valve lengths are different for compression, valve springs are different for the two cams. Then the harmonic balancers are different, with a higher weight on the 4bbls.
