Wtb 3.23 gears for 8.2
Looking for a nice set of 3.23 gears for 8.2. Posi Carrier also. John 330 618-6583
I had contacted a major gear maker a while back about doing a new run of 3:23 ratio gear sets. Seems like there is pent up demand for this.
I believe it would have been about $500 per set if they made > 40 sets. |
Considering they fit Olds too, 40 sets would be only a gesture.
That is a bit of an investment though... |
5 Attachment(s)
I have a set of 3.23 gears still attached to an open carrier that came out of a 66 GTO if that is what you are looking for. I also have the spider gears and clutches to convert an open carrier to a posi unit.
I will also have a set and carrier coming out of a one owner 70 GTO in the next week or so.
The above pictured clutches & side gears can only be used in the style of posi carrier, they came out of. They cannot be used in a single track carrier.
The round eared factory Eaton clutches are typical to being used in posi carriers for 8 7/8 P series, 8 7/8 MP series, 12 bolt Chevy car or 12 bolt Chevy truck. Different designs of posi side gears were designed to accept that style of clutch, 28, 30, & 31 spline side gears w those regular clutch type sets, as well as governor lock posi units. |
This style of Pontiac 8.2 gear set was introduced in late '69 Birds. Just something to note if trying to EASILY mate with an earlier style 8.2 Pontiac carrier. |
Still need these gears.!!
