76 versus 73/74
All, I know there is a difference in the motor mounts used in a 76 versus a 73 / 74 but I am wondering if the 76 frame still has the holes for the 64-74 frame brackets or at least can they be drilled?
Thanks! Mark |
I think the holes are there. I have a 73(with old style mounts) and a 75(with clamshells). As best I can see on the 75, considering the engine is in the car, I see holes in that area where 73-74 pedestals would be.
My question would be why you would want to replace the superior clamshell motor mounts with the inferior older style? |
You might check with Butler Performance for adapters. You could call them to see if they can tell you if there are any problems with the way their adapters fit: https://butlerperformance.com/c-1393...-adaptors.html
