need route info for reverse lock out wire
working on my 72 and i am running some of the wiring for the car , not sure how the reverse lock out wire runs . i now how it starts at the switch , but lost after that
also need to know which hole does the tach wiring go thru
Reverse lockout wire? There is a mechanical linkage that goes from the base of the steering column to the transmission.
you need an assy manual...its a great investment, and you would get instant answers to your needs
Tach wire goes through a big hole by the fuse box, and has a boot with a nose on it to keep water out. Grommet has a slice in it, which should face downward. Hole in Grommet is big enough for 10 wires , but thats whats used. https://forums.maxperformanceinc.com...2&d=1593750831 |
I like the input and photos that the guys here give out, plus the manual sometimes is not very clear on some items , but I guess I better get them |
just saying that if youre not familiar with these cars, a manual has all the info you need. even a cheap chiltons paper back one can be a huge help but a GM one is excellent even if just for things like torque specs etc. |
