David Jones..U out there ?
Just curious if you got my PM I sent a couple of weeks ago?
How's shoulder doing? |
Hey Troy. Been busy as a one armed paper hanger here at work and at home. Sorry I missed the PM. Answering.....
I just didn't want to many irons in the fire..:) |
The arm is better. Still no feeling in about half the arm below the elbow. Done with therapy and while it's a bit achy, it works. Strength is coming back. Installing this engine/trans has been a challenge....probably more than I should have done but I might actually get to start the engine this evening.
I hope that you get well soon MR Jones.
Glad your doing well buddy.... My forearm is still numb on top also..... and yes, the whole arm aches at times also, even up to the shoulder..... weird ..... Wound is finally all healed closed, it took awhile where he tied the knot. Be Well Troy |
My doc glued my incision shut but they still managed to pull the ends of some internal stitching out that had worked their way outside while it healed. At random times the elbow will ache, the upper arm will ache and from time to time I find myself straightening it out all the way....simply because it feels good to do that. Most times I don't even realize I'm doing it. I have noticed that I'll start to do something that requires force that I might normally use my left arm (the "bad" one) and I'll have to figure out how to swap sides and do it with my right.
Better every day though. Good your doing better too. DON'T over do it! |
Hope all heals up for ya...sounds like you will be having fun flooging gears !!! |
